2 Pages V  < 1 2
> Head Gasket Question
post Feb 10, 2009 - 12:57 PM
92-gt
Joined Jan 22, '09
From Bremen
Hijack threads???
This thread was a few weeks old. I had a very similar problem as he did. I used the search option, and this was the closest thread I could find to my symptoms. I would think it would be better to post in a thread that is related to the matter than to make a new one...
post May 12, 2009 - 11:12 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Remy @ Jan 17, 2009 - 10:26 PM) *
I don't trust ebay gaskets you don't want to cheap out on the head gasket heres the part number for 5sfe metal head gasket 11115-74120 don't forget to get new head bolts too.
Has anyone actually done this before?
God made man....
Everything else...
Made in China
post May 12, 2009 - 11:54 PM
dgbldr
Joined Sep 19, '08
From Michigan
To both people with this problem:
You need to diagnose the problem before you go wasting a bunch of time and money replacing parts at random.
The easiest test is the internal leak test. Read this and see "internal leak test":
http://www.familycar.com/Classroom/CoolingSystem.htm
post May 13, 2009 - 12:53 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
i am in the process of rebuilding three celicas right now... 2 5s-fe's.. let me know if you have any questions
Breaking Axles...
post May 13, 2009 - 2:16 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (dgbldr @ May 12, 2009 - 9:54 PM) *
have done this already and confirmed it using this
http://www.arrowheadradiator.com/head_gask...n_leak_test.htm
need to replaca the radiator too because of the crack.
God made man....
Everything else...
Made in China
post May 22, 2009 - 12:57 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (nics @ Jan 18, 2009 - 1:00 PM) *
QUOTE (Remy @ Jan 17, 2009 - 9:26 PM) *
ok thanks! checked the price out from 1sttoyotaparts. do i order it from toyota? part number pls. thanks
btw, why do we have to change the head bolts if we replace the head gasket?tnx
God made man....
Everything else...
Made in China
post May 22, 2009 - 1:09 AM
laff09
Joined Jul 28, '06
From Delaware
headbolts are built to stretch once torqued properly the first time. You dont want to use them again
post May 26, 2009 - 7:05 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
^^ i c. ordered em already. just waitn for it.
God made man....
Everything else...
Made in China
post Jun 2, 2009 - 6:00 PM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
How did it turn out? I just finished up doing the same thing, mine was foaming out the radiator.
post Jun 2, 2009 - 6:49 PM
azn87
Joined Aug 2, '06
From bay area
sorry to steal thread but im juss had the same problem happen to me, but now i leaking oil mixed with coolant. And the other day i think thursday or friday is was over heating on me.
post Jun 3, 2009 - 1:31 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (56willysnut @ Jun 2, 2009 - 4:00 PM) *
Its still in the shop. Hopefully i get it this weeked. My radiator was cracked too bec of too much pressure. What do you mean foaming out?? tiny bubbles?
QUOTE (azn87 @ Jun 2, 2009 - 4:49 PM) *
Is your radiator look like this?
http://www.6gc.net/forums/index.php?showto...7537&hl=oil
I suggest you get it tested ASAP.
Don wait like i did and have more problems down the road
God made man....
Everything else...
Made in China
post Jun 3, 2009 - 4:08 PM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
My head gasket was caused from a leaky water pump, caused rear main oil seal to go mamaries up. Spent the last three days under the hood and ready to get it completed. My rad looks good. No leaks
post Jun 3, 2009 - 10:08 PM
azn87
Joined Aug 2, '06
From bay area
i had juss replaced my radiator, also juss replaced my rear main seal because oil was shooting into the clutch. so basicly i had the rear main seal replaced and my clutch. so now my water pump is leaking and im guessing my head gasket had juss went.
post Jun 4, 2009 - 8:51 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
Update: The shop just told me that my head was gone... frown.gif Im now in the market looking for one. He found a head that cost 150 and it needs a valve job for 185. Does the prices sound right?
So for you guys who's having problems, get it fixed asap
God made man....
Everything else...
Made in China
post Jul 7, 2009 - 2:30 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
God made man....
Everything else...
Made in China
post Jul 8, 2009 - 2:00 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
QUOTE (nics @ Jul 7, 2009 - 12:30 PM) *
So it turned out that it was indeed the head gasket, but went on too long so you had to replace the head as well? Did you have to replace your radiator as well?
Glad it's fixed though!
QUOTE (92-gt @ Feb 9, 2009 - 5:50 PM) *
Yes, I replaced it a couple days ago..
I know the thermostat is newer, because I was there when the previous owner replaced it.
But I also know when he replaced the radiator, for some reason he also put stop leak in. Why he did it is beyond me.
I would say maybe the thermostat is sticking shut, but the lower hose feels like it is getting warm, although it isnt as warm as the top.
Could this cause it?
I have the metal head gasket, bolts, thermostat, thermostat gasket on the way from 1sttoyotaparts.com as well as a gasket kit for all other gaskets. I just wanted to have it just in case, but I want to make sure of what my problem is before I rip into it...
I'd suggest that perhaps that's your problem - the stop leak is clogging the radiator. If I were you I'd definitely start with the simple stuff like replacing the thermostat. It's SUPER cheap and SUPER easy to do. It's possible that even if it was replaced fairly recently, it was either put in incorrectly, or it's just a faulty part.
edit: oh wait, I just realized the post from 92-gt is like mad old. Oops.
This post has been edited by GriffGirl: Jul 8, 2009 - 2:01 PM
post Jul 9, 2009 - 12:03 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (GriffGirl @ Jul 8, 2009 - 12:00 PM) *
Actually it was fixed last month. Part is head gasket, part of it is the actual head. The holes of the water jacket were corroded and the mechanic recommended to get a new head so I got one.
I replaced the radiator too! It was cracked due to too much pressure.
Water pump was replaced, oil pump seals and gasket, thermostat, timingbelt, idle tensioner pulleys, cam seals, bi-metal switching valve, pcv valve, rad hoses and other lil stuff.
So far in its 1st 1k miles it went pretty fine, drove 200 miles on a 90 degree day.
God made man....
Everything else...
Made in China
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 27th, 2024 - 11:02 AM
