> Possible Fuel Pump Issue??????
post Jan 20, 2009 - 3:41 PM
elgordo_pr88
Joined Jan 20, '09
From Eustis, Fl
I think i may have a possible fuel pump problem. I have 94 celica ST and the car starts but won't stay on. I'm thinking its a problem with the fuel pump. Does anyone know which wire gives the electricity to the fuel pump? Or has anyone else had this problem? LMK
post Jan 20, 2009 - 5:42 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
under the hood, on the drivers side very close to your brake master CYL, and such on the firewall, there is a little box that says "DIAGNOSIS" open it and find the two terminals "B+" and "FP" bridge the two with a wire and listen for the flow of fuel which you can hear both at the rear drivers tire, and in the engine bay. it should be a steady sound. if it is, try to start the car, if it runs fine, its will probably be something called COR, Circuit Opening Relay.
post Jan 20, 2009 - 11:08 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
if you hold the throttle open slightly does it stay running?
Lo-Fi Version Time is now: November 23rd, 2024 - 6:44 AM
