> seems to be a problem with most celicas..
post Jan 21, 2009 - 6:19 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
the weatherstrip around the headlights.
finally decided t make an attempt to make it look better, and i used a hot glue gun. works great! id take pics, but you can even see any of the work ive done just pull up the seal and hotlue that baby on there!
hopefully this helps others.
post Jan 21, 2009 - 7:17 AM
stetsonaw
Joined Aug 3, '07
From Bellevue, Nebraska
i used 3m tape on mine, good idea though, didn't have a glue gun handy, and i hate that stringy crap that get's left behind.
~Andy
Check out my Droid Goodies
| My Flickr
post Jan 21, 2009 - 7:21 AM
hot glue wont hold up to the variety of weather conditions all too well. but good job fixing the problem smile.gif
post Jan 21, 2009 - 12:14 PM
zero07
Joined Apr 15, '07
From san antonio tx.
The only thing about hot glue is if you drive with your lights on for an extended period of time wont it just heat the glue again and come apart?
post Jan 21, 2009 - 3:48 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
lol well, i thought that the heating up would be a problem but i live in wa. and its always effing cool as hell. i havent had any problems with it so far.. ill let you guys know when its fails.
post Jan 21, 2009 - 11:24 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I used clear silicon two years ago and they haven't moved since.
post Jan 21, 2009 - 11:47 PM
azian_advanced
Joined Apr 18, '05
From Calgary
yeah silicon is probably one of the best solutions.. i used it to mount my fog lamps to the fog bezels and my lamps haven't fallen come off. it's less brittle than most glue so it's more resistant to weather change, cracking, moisture, and shock.
post Jan 22, 2009 - 12:42 AM
richee3
Joined Jun 29, '08
From Denver
One of the very few Celicas that is around me took their low beam weatherstrips completely off and use silicon in it's place. Like a silicon ring around the headlight instead of the weatherstrip. Doesn't look too bad, but it would look better if they had just left the weather strips in there.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
Lo-Fi Version Time is now: January 10th, 2025 - 11:47 AM
