> adjusting headlight beam
post Jan 24, 2009 - 8:12 PM
Coligion
Joined Sep 27, '07
From Tucson, AZ
I did some searching through the forums and found this topic with some good pictures....
http://www.6gc.net/forums/index.php?showto...l=headlight+aim
However, I have turned all these screws many, many times and I can't get anything to change (vertical or horizontal). Is there something else I need to loosen up before the housings will adjust? I am only trying to adjust the low beams, but like I said, the pattern remains no matter how much I turn these screws. Thanks for the help.
post Jan 24, 2009 - 11:23 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i know it takes a lot of turning before you see any difference.. it helps to make a reference point on the wall or something to compare to when you're adjusting the angles... do all your lights not adjust?
Lo-Fi Version Time is now: December 12th, 2024 - 3:38 PM
