> Transmission question, 1994 Celica ST
post Jan 25, 2009 - 12:31 AM
92-gt
Joined Jan 22, '09
From Bremen
So I went and picked up this car today and I knew before I got there, that there was some transmission issues.
The owner said that it would just pop out of third gear, and I was thinking maybe the linkage was messed up.
Well, when I took it for the test drive, it would go into 3rd gear, but it would just free rev.
When shifting into 4th, it grinds a little bit, and then whines when accelerating.
1st, 2nd, and 5th are all fine as well as reverse.
What do you think could be causing this?
Also, it looks quite easy to replace the transmission on this car, is it?
Thanks in advance!
post Jan 25, 2009 - 12:34 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
extremely easy to replace the trans. You can do it all by yourself. I can do a clutch job in a little under 2 hours by myself. For your issue your trans is screwed. Does it have gear oil in it? Either way you'll need a new one.
94 Celica gt white (sold)
post Jan 25, 2009 - 12:40 AM
92-gt
Joined Jan 22, '09
From Bremen
Well, I am going to check it out a bit more thoroughly tomorrow..
I kind of figured that it was f'd but I just wanted to get some more opinions.
Also, when I got home and was looking under the hood a bit, I noticed one of the bolts holding the trans. to the block was un-threaded quite a bit. Could this cause the issue?
post Jan 25, 2009 - 12:57 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So you're saying the bolt wasn't screwed all the way in? If so, It shouldn't play any role, because there are atleast 9 more bolts holding the transmission in.
post Jan 25, 2009 - 1:43 AM
92-gt
Joined Jan 22, '09
From Bremen
Alright, thats what I was wondering. I guess the original owner had the clutch replaced not too long ago so idk whether they didnt get something right or what the deal is..
Lo-Fi Version Time is now: February 24th, 2025 - 2:10 AM
