> 7AFE TO 7AGE, FRANKENSTEINS 6G ST BUILD UP
post Jan 26, 2009 - 4:12 AM
i_wanna_go_fast
Joined Jan 26, '09
From massachusetts
i have officially made the journey from domestics to imports as i purchase my 97 celica. i refuse to drive anything the way i buy it, so heres what i've come up with so far......
the plans for my 7afe....
4AGE (16 valve) head
2ZZ (11.25 compression?) pistons and rods
jac knife the crank
CRANE CAMS RPM 2600-6000; Adv. Dur. 292 Int./302 Exh.; Valve Lift .458 Int./.472 Exh.; Lobe Angle 110 deg.;
PACESETTER HEADER
OEM exhaust (less the resonator and cat)
extreme port and polish on the head
HKS valve springs
HKS adjustable cam gears
any ideas suggestions comments are enthusiastically welcomed.....
post Jan 26, 2009 - 7:22 AM
trdproven
Joined Aug 2, '05
From Guam
never heard that done before - this frankenstein.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 26, 2009 - 11:26 AM
nik
Joined Sep 30, '02
do a search on 7agte i have a full build
http://www.6gc.net/forums/index.php?showtopic=21831
also check 7age
and there are things that arent going to work that you have listed
QUOTE (i_wanna_go_fast @ Jan 26, 2009 - 3:12 AM) *
jac knife the crank
PACESETTER HEADER
HKS valve springs
This post has been edited by nik: Jan 26, 2009 - 11:31 AM
post Jan 26, 2009 - 12:31 PM
i_wanna_go_fast
Joined Jan 26, '09
From massachusetts
i have been doing research all week. although i would love to boost this little puddle jumper, i just dont know if its a headache i want to deal with right now. although the ebay "tuner kits" are conveniently priced under $1000 and include just about everything you need, less the manifold and downpipe.
just about every post i've seen for the NA 7A, recommends swapping to a G series head. Boring out the cylinders to 82mm would allow the 2ZZ pistons to slide right in, and i just discovered that they now offer 13:1 pistons for the 2ZZ. The new head and HKS cam gears require swapping the timing belt with one from a porche. i dont have it right in front of me which one, but it is in my records. There have been several people who have done this conversion already, however none who tried the 13:1 piston or extreme cams. i plan to use the same methods with the air and fuel as i used on my 98 ford contour zetec. after tripping the CE light with the air flow, the new 5th injector was just enough to straighten that out plus the new straight through exhaust makes an impressive improvement over the OE 110hp. returning to the celica, with a dry sump oil pump, custom IM, bigger throttle body, and a whole lot of hard work and tuning. i believe i can bring a +250hp 7a to the table.
on the other hand........... it could just snap craccle and pop when i try to start it...... that would succ
post Jan 26, 2009 - 1:22 PM
nik
Joined Sep 30, '02
i just recommend that post cause its pretty much the same as building a na
there has been alot of post on the pistons and rods to use
the 2zz rods wont work with the 7afe crank
http://www.6gc.net/forums/index.php?showto...821&hl=7age
http://www.6gc.net/forums/index.php?showto...054&hl=7age
QUOTE (i_wanna_go_fast @ Jan 26, 2009 - 10:31 AM) *
post Jan 26, 2009 - 7:03 PM
i_wanna_go_fast
Joined Jan 26, '09
From massachusetts
maybe a turbocharged slightly modified 7afe would be a better option.... economically.... a rebuilt 7afe will run about the same as a heavy duty set of pistons and rods.............. and the turbo would be much cheaper than having all the machine work done.......... kinda feels like im right bac where i started........
post Jan 27, 2009 - 11:21 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
I found a 20v head for sale near me yesterday and am considering doing the same thing... but not after I research the hell out of it first tongue.gif
post Jan 27, 2009 - 12:02 PM
nik
Joined Sep 30, '02
the biggest pain is getting the timing dailed in right alot of math
you gotta set up that belt right
also you have to redo your coolant setup
but it can be done
post Jan 27, 2009 - 1:10 PM
i_wanna_go_fast
Joined Jan 26, '09
From massachusetts
for now i think i will just keep researching my options. when the time comes to add the GFS to the car, i will just have to go over the finances for the project.
off topic.... there should be a collection of carbon fiber pieces available for the 6g and the 7AFE in the months to come. but no one knows yet!!! biggrin.gif wink.gif
post Jan 27, 2009 - 1:49 PM
Akirad1
Joined Jun 2, '08
From Fort Worth, Texas
same here im deff gonna watch this topic. i was either gonna save the for a 4A, or the ge hybrid
post Jan 27, 2009 - 4:27 PM
nik
Joined Sep 30, '02
here is a good 7age set up i looked at this in my early days of my 7agte build
http://te51levin.superjamie.net/7ageintro.html
This post has been edited by nik: Jan 27, 2009 - 4:33 PM
post Jan 28, 2009 - 12:45 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Some info first off...
Use 4AG pistons. They fit the 7A and are much easier to find in a wider range of compression... 13:1 comp is too high for regular street use, unless you plan on building a straight race engine or something... As for rods... custom or aftermarket. Re-engineering 2ZZ rods is gonna cost a bit and not perform as well as aftermarket rods due to incorrect stroke ratios. As for the head... go for the 20V head. If you use the 20V head, you can use the existing 7A water lines... but if you use the 16V head, you'll have to redo everything.
That said... I think you're biting off more than you can chew. Based on your research so far... you're just speculating when you talk about 250hp and such. FYI, a 7AGE hybrid in n/a trim doesn't make significantly more power than a stock 4A. Maybe 5-10 overall across the powerband in stock trim. Tuning for 200+ hp isn't amateur stuff... let alone 250. Toyota Formula Atlantic motors only make 240hp at 10,000 rpms. Granted they're 1.6 liters, but consider the build cost and tuning requirements of those engines and know that they aren't very streetable motors, then go back and reassess your goals. You're starting with a base motor that is 160hp at best (20V)... and are attempting to increase that by 100hp. It is no easy task and requires more investment than bolt-ons.
If you're looking for power... turbo the 7A. If you wanna realistic power goals from a 7AG hybrid... around 180hp is more realistic and would still require a good deal of tuning.
This post has been edited by Kwanza26: Jan 28, 2009 - 12:47 AM
post Jan 28, 2009 - 11:42 AM
nik
Joined Sep 30, '02
nicely said how you been B
QUOTE (Kwanza26 @ Jan 27, 2009 - 10:45 PM) *
post Jan 28, 2009 - 12:18 PM
i_wanna_go_fast
Joined Jan 26, '09
From massachusetts
thanks for the info nik. the turbo is probably a better option financially plus it will add some color and liven up the engine bay. when i get ready to do the labor im sure you'll be hearing more from me. thanks again
post Jan 31, 2009 - 5:41 PM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
Kwanza26 Posted Jan 28, 2009 - 1:45 AM
nothing to do with this topic, but the second generation Prius runs a maximum of 13:1 compression ratio
Trust me, I do this every day
post Jan 31, 2009 - 6:08 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (silver6gc @ Jan 31, 2009 - 6:41 PM) *
and the prius does not use an otto cycle engine like everyone else does, it uses an atkinson cycle engine.
Lo-Fi Version Time is now: February 20th, 2025 - 3:02 PM
