> 7th gen Corolla owner adding BEAMS power!
post Jan 28, 2009 - 11:00 AM
daCoupe
Joined Jan 28, '09
From Victoria, BC
Hello 6gc.net!
I'm a proud owner of a 7th gen Corolla wagon seeking 6th gen Celica BEAMS knowledge. The high mileage 7AFE (214,xxx miles) in my AE102 is burning a lot of oil and probably has half the factory rated hp. So instead of replacing the valve seals / piston rings or swapping in another A-series motor (4AG(Z)E / 20v), I've acquired a 3SGE BEAMS to build the ultimate NA grocery getter / baby-mobile! With all your help, I should have the tools to accomplish this.
If I can learn a thing or two about Celicas and make some friends, that would be a huge bonus!
post Jan 28, 2009 - 11:29 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Sweet, that sounds like a great swap. Let me know if you have any questions or need a hand with it. You might want to check out my website for some inspiration too: http://www.phoenixtuning.com
And welcome to the forum!!!`
-Doc
This post has been edited by Dr_Tweak: Jan 28, 2009 - 11:30 AM
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 28, 2009 - 7:34 PM
daCoupe
Joined Jan 28, '09
From Victoria, BC
QUOTE (Dr_Tweak @ Jan 28, 2009 - 12:29 PM) *
-Doc
Thanks Doc! My motor set didn't come with axles or mounts so my first questions pertain to those items. What USDM axles / mounts can I use? A friend of mine will help me make custom mounts as necessary since I'm sure they won't all line-up anyway. The axles are a bit more challenging, that's where you come in. If you can give me some insight, that would be greatly appreciated!
post Jan 29, 2009 - 10:17 AM
Dr_Tweak
Joined Mar 31, '04
You're going to be a pioneer as far as the axles, likely at least one will be custom. I can help you out with how to go about making them though smile.gif
-Doc
Lo-Fi Version Time is now: January 10th, 2025 - 12:48 PM
