Firebird problems, help..? |
Jan 28, 2009 - 9:36 PM |
Enthusiast Joined Oct 16, '08 From Oil City, LA Currently Offline Reputation: 0 (0%) |
By bf recently got a firebird and hes almost done fixing it, except for what happenend the other day. He took it down the road for a test drive, and at first it drove perfectly and then died. and would not start. he has changed out coil packs, and tried switching out the coil pairs and that didn't work. He said the engine will try to start, and he checked to see if the spark plugs were firing, which they are. Do you guys have an idea of what it could be thats going wrong?
Any help would be appreciated. -------------------- If knowledge is the key then idiots are locked out
Jan 29, 2009 - 1:05 AM |
Is it cranking?
Is he getting fuel? Checked fuses and relays? Out of gas? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jan 29, 2009 - 3:19 AM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
Diagnosis: You bought a Firebird.
Cure: Get a Japanese car LOL JK. This post has been edited by Random_Stranger: Jan 29, 2009 - 3:19 AM -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Jan 29, 2009 - 3:37 AM |
Enthusiast Joined Aug 19, '08 From New Brunswick Currently Offline Reputation: 3 (100%) |
^ pretty much sums is right up lol, id say fuel is an issue, good luck with it tho
-------------------- i hate snow, missing my celica |
Jan 29, 2009 - 3:28 PM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
What year, what motor? I've owned a bunch, still have one (hence the screen name). I mihgt be able to help some.
Jan 29, 2009 - 7:02 PM |
Its a 1996 firebird with a 3800 series V6. when you turn the key, it will make the noise of trying to crank and thats all it does. the gas is not bad because we checked it and its fine.
Jun 10, 2009 - 12:10 AM |
Enthusiast Joined Sep 1, '08 From STL Currently Offline Reputation: 1 (100%) |
Jun 10, 2009 - 6:43 AM |
whats his fuel pressure?
probably not related to the no-start, but has he done the lower intake manifold gasket job yet? if no then he needs to get that done ASAP before he trashes the engine. -------------------- |
Jun 10, 2009 - 7:51 PM |
Crank angle sensor? Not sure if those things even come with one, unless its the old Distributor cap and style. My previous boss had to take off his waterpump just to get to the distributor. Sucks to have a Domestic car. Its even worse when you know you gotta take off your v8 intake manifold to get to your starter. That's a caddy for u!
Jun 15, 2009 - 5:58 AM |
Enthusiast Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
My wife has the same car (98). She had a really big problem with vapor lock. She would be driving down the road and the car would just die. Sounds like it could be the same thing.
Jun 17, 2009 - 12:12 PM |
My wife has the same car (98). She had a really big problem with vapor lock. She would be driving down the road and the car would just die. Sounds like it could be the same thing. vapor lock on a fuel injected engine? vapor lock is when fuel in the fuel line turns to vapor and cuts liquid fuel flow to the carb, carb work on vapors. in a fuel injected setup like those cars the fuel is constantly circulating in a loop to the engine and back to the tank, always have fresh cool fuel at the rail and moving through the rail, to vapor lock you'd need to slow the flow of fuel dramatically. sounds more like a bad fuel pump thats heating up and dieing out after use for a while, its a common way for them to fail. or she's runing the fuel tank so low that its sucking fumes -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:25 AM |
