> Can someone tell me how to take this off!?, stiffener plate? blocking the oil pan...
post Jan 31, 2009 - 6:23 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
trying to get the oil pan out to reseal, but its being a pain.
the front motor mount is out. crossmember is pushed to the side, there is working room, but this bolt holding this shield is not removable, and there is a big metal arm and the shield held by it which is blocking the pan.
This post has been edited by samir0189: Jan 31, 2009 - 8:26 PM
My F/S Thread!
Ferdi says (11:29)
post Jan 31, 2009 - 7:03 PM
eggman40
Joined Aug 17, '04
From California
It looks like that bracket that goes over that bolt needs to be taken off from the other end.... its kinda hard to explain in words but.. it looks like you already took off the nut holding one end of that bracket. Just release it from the other end.
post Jan 31, 2009 - 7:34 PM
samir0189
Joined Mar 8, '08
i understand what you mean. Its just that the other end is really hard to access. Its buried under tons of lines and wires and bolted up on the underside of the intake manifold. I can touch it from under the car but i cant get any tools in there with me.
Its pretty much inaccessible from the top of the motor cause its on the underside.
Tomorrow morning i will try to get it out again, but idk how!
I was trying to pry it off but its a super thick metal bar.
My F/S Thread!
Ferdi says (11:29)
post Jan 31, 2009 - 11:17 PM
it's the intake manifold stay (support).
Like egg said it bolts from the back of the intake mani to the bottom there. Just get it from underneath, reach up and it's a 12 or 14mm, I can't remember off hand.
post Feb 1, 2009 - 7:17 PM
samir0189
Joined Mar 8, '08
My F/S Thread!
Ferdi says (11:29)
post Feb 6, 2009 - 8:31 PM
jbspeed
Joined Feb 6, '09
From Florida
Samir, I have already torn my engine down to the block from above, but now I am having the same problem as you. I removed the front engine mount and disconnected the front crossmember. How did you get the crossmember to swing away to get to the bottom bolt blocked by it?
post Feb 7, 2009 - 8:30 PM
samir0189
Joined Mar 8, '08
QUOTE (jbspeed @ Feb 6, 2009 - 8:31 PM) *
loosen the bolts connecting the rear motor mount to the crossmember, the ones underneath the little rubber caps. don't take them out completely, just loosen enough and the crossmember will swing out of the way to get to the goodies under it. biggrin.gif
My F/S Thread!
Ferdi says (11:29)
Lo-Fi Version Time is now: November 25th, 2024 - 11:39 PM
