> v6 engine swap..
post Feb 1, 2009 - 3:45 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
ive decided that the 1MZ-FE is the best for me,
just wondering what i need all together, ecu tranny and whatnot
asking for help thank you
post Feb 1, 2009 - 3:46 PM
manphibian
Joined Oct 13, '06
From UK
http://www.6gc.net/forums/index.php?showto...hl=1mz-fe++swap
post Feb 1, 2009 - 8:46 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
lol, i got that but do i need to rewire everything or what?
all i need is the motor, tranny, axles, motor mounts?
anything else?
post Feb 1, 2009 - 9:06 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
QUOTE (JustinCapps @ Feb 1, 2009 - 9:46 PM) *
anything else?
oh no, your 4 cylinder ECU can run a 6 cylinder distributor less engine just fine! rolleyes.gif
post Feb 2, 2009 - 12:11 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
^^ is he joking or being serious??
i cant tell.
i wouldnt think that it would work..
post Feb 2, 2009 - 8:41 AM
Bitter
Joined Mar 11, '06
QUOTE (JustinCapps @ Feb 2, 2009 - 1:11 AM) *
i cant tell.
if you're asking that then i really really hope that a reputable shop is doing this swap for you.
post Feb 2, 2009 - 10:17 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
to be clear, you need the 1MZ ECU and wiring harness. get in touch with Dr Tweak. he can help with wiring conversions
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 2, 2009 - 10:30 AM
trdproven
Joined Aug 2, '05
From Guam
try to get as much needed for the v6 swap. Better to have it and not need it than to need it and not have it. - haha so cliche.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 2, 2009 - 11:16 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
lol, of coursee a shops going to do it for me, i just would like to have everything ready for the shop so they cant fuk me over.
make sense?
post Feb 2, 2009 - 12:16 PM
plasticgeordie20...
Joined Jan 3, '09
From Middlebrough, UK
I am getting a garage to do mine at the moment you will need to fabricate a custom engine mount, stiffen up the existing engine torque mount, uprate the clutch, replace/modify the flywheel, fabricate a custom header. Adapt the tacho to read a 6 pulse input instead of 4 pulse, standalone ecu or 1mz-fe ecu and full wiring loom
post Feb 21, 2009 - 12:05 PM
grasby
Joined Dec 21, '08
From jacksonville, ar
would you really have to modify or replace the flywheel?
if your buying the right enginge an tranny shouldnt they already work together?
This post has been edited by grasby: Feb 21, 2009 - 12:05 PM
post Feb 21, 2009 - 12:19 PM
plasticgeordie20...
Joined Jan 3, '09
you will need to modify the flywheel as the celica clutch will not fit on the camry flywheel, and the celica flywheel doesnt mate direct with camry crank shaft.
So you either have to drill new holes in the exisitng flywheel,
or ideally source a lightened flywheel and drill new holes in that.
I have a fidanza flywheel which will be mated with a black diamond sports clutch when mine gets done next month
post Feb 21, 2009 - 12:24 PM
grasby
Joined Dec 21, '08
oh ok, i see now
thanks for clearin that one up
Lo-Fi Version Time is now: December 3rd, 2024 - 9:22 AM
