> Fluctuating idle and slight miss, 5th gen. Please help.
post Feb 1, 2009 - 9:53 PM
92-gt
Joined Jan 22, '09
From Bremen
Ok, so I havent gotten any help on the other forum that I regular, so I figured I would ask here as well.
I have a 1992 Celica GT with a rev 2 5sfe.
Friday I was driving up to my college and it seemed like it was running ok. When I was cruising though, and kept my foot at a steady speed, it seemed to jerk a little bit. If I gave it a bit more throttle it would be ok, or if I let off it would be ok.
When I came back outside to leave, it idled really low, and died, but I managed to limp it home ok.
I swapped TPS's with my 6th gen, and it idles a bit better, but it still fluctuates and misses.
All of my vacuum lines are ok.
I checked my IACV and it is not plugged.
When I am at idle sitting still, and I rev it up, if I slowly rev, it seems like it misses, but if I do it quickly, it is ok.
Any ideas of what it could be?
Could it be a bad o2 sensor?
I need to get my car running properly because I have to go to college, and I dont have a transmission in my 6th gen yet.
Please give me any ideas that you guys have, I would really appreciate it.
Thanks
-Ryan
post Feb 2, 2009 - 10:29 PM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
Start with basics, when was the last time it had a "tune-up"?
Trust me, I do this every day
post Feb 2, 2009 - 10:30 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
cap, rotor, plugs, and wires are all in order and relatively new?
post Feb 3, 2009 - 7:48 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i agree w/ the two posts above. it is most likely a plug, wire, cap, or rotor issue. or a combination of any of those.
do the above mentioned items, clean whole throttle body, then look into your TPS, IACV, ignitor, coil, cam pos sensor, in that order.
Lo-Fi Version Time is now: February 22nd, 2025 - 12:01 PM
