> celica shaking problem.
post Feb 2, 2009 - 12:17 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
going about 60mph, when i accelerate my car starts to shake.
replace the spark plugs, just had timing done, change my oil yesterday, had my balance done the day before, going to have the alingment done tomorrow.
i really dont know what it could be..
post Feb 2, 2009 - 7:56 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
QUOTE (JustinCapps @ Feb 2, 2009 - 12:17 AM) *
Could be a number of things, maybe the alignment, may be a bent rim, may even be the engine mounts.
post Feb 2, 2009 - 11:19 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
i think t might be the mounts.. its going in today hopefully ill be able to fix this problem... really dont think its anything to do with my wheels/alingment. because pulled my ebrake in a parking lot and just sat there spinning my tires and my car didnt hop around or anything..
post Feb 2, 2009 - 12:15 PM
fosbal
Joined Jan 28, '09
From Michigan
It could also be a bad inner CV joint.
This post has been edited by fosbal: Feb 2, 2009 - 2:42 PM
post Feb 2, 2009 - 3:46 PM
koby15
Joined Nov 28, '08
From cheney
ya mine has the same probelm and schwabs said it was two bent rims but then agiain i only encounter it at 70
post Feb 2, 2009 - 6:00 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
http://www.6gc.net/forums/index.php?showto...hl=acceleration
My F/S Thread!
Ferdi says (11:29)
post Feb 2, 2009 - 10:24 PM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
Just as a reference, the magic number for bent rims is 45 mph (if you work at a dealer, you'll know hat i'm talking about) and they would vibrate whether you're accelerating or not. Alignments don't EVER cause vibration problems, if anyone on here tells me they had their alignment corrected and it fixed a vibration, I will guarantee you the shop lied to you about what they did. Mounts or a driveline issue is most likely in this case, it is possible but HIGHLY unlikely that worn suspension bushings could be the cause.
This post has been edited by silver6gc: Feb 2, 2009 - 10:25 PM
Trust me, I do this every day
post Feb 9, 2009 - 2:02 AM
ej8ferio702
Joined Apr 23, '08
From VEGAS
yes i have to agree with others it could be the bushings in your engine mounts, this happened to my civic only encounters the shaking at high speeds/rpms
post Feb 9, 2009 - 2:32 AM
trdproven
Joined Aug 2, '05
From Guam
can't be the mounts because when you are moving the shaking will get less. You can tell its the mounts because at low idle thats when you feel it the most not at high RPM or speed thats when you less feel it or even at all.
This post has been edited by trdproven: Feb 9, 2009 - 2:33 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 9, 2009 - 10:33 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
well pop ur hood and start the car while watching the engine, if it shakes pretty violently u have a mount issue
post Feb 17, 2009 - 5:24 PM
crankyelbow
Joined Feb 11, '09
From south chi burbs
QUOTE (trdproven @ Feb 9, 2009 - 3:32 AM) *
post Feb 17, 2009 - 8:26 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
well< i had the front mount replaced< and it made the shaking worst...
the mecanic told me that it very well could be a axle..
if thats not the case< its the tranny< if thats the case im just going to have to have it rebiuld< which is something i would love to do.
post Feb 18, 2009 - 2:28 PM
fosbal
Joined Jan 28, '09
From Michigan
As I've stated earlier in this thread, I think you have a bad cv joint. I had the same problem and replaced the driver's side axle shaft (problem side). Passenger side was ok.
This post has been edited by fosbal: Feb 18, 2009 - 2:30 PM
post Feb 20, 2009 - 8:02 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
QUOTE (fosbal @ Feb 18, 2009 - 3:28 PM) *
taking it in on monday well find out then...
Lo-Fi Version Time is now: November 30th, 2024 - 6:44 AM
