> new problem in my All-trac, Update...its fixed!!!!!!
post Feb 4, 2009 - 10:42 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
ok so last night i installed my manifold and valve cover after getting them powdercoated. sexy as hell by the way. anyways now my yellow fuel pump relay is buzing like crazy and my ECU dosent seem to be powering up. i have an AEM EMS and its not talking to the laptop. i checked the power at the relay and it was like 9 volts. i must have a serious power drop somewhere.
This post has been edited by Smaay: Feb 12, 2009 - 11:20 AM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 4, 2009 - 10:46 AM
IIRC you can bypass the relay by jumpering fp and B+ in the diagnostics box.
post Feb 4, 2009 - 2:08 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
stupid question, but is the battery actually charged? take it to autozone to get tested, and oif its low they'll offer to charge it free. go back in an hour or so and pick it up then try again!
post Feb 4, 2009 - 5:57 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
you sure you plugged everything back in correctly?
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 4, 2009 - 8:37 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (stephen_lee @ Feb 4, 2009 - 11:08 AM) *
yeah i ahead of you there
oh here are pics of the powdercoating
This post has been edited by Smaay: Feb 5, 2009 - 11:00 AM
post Feb 5, 2009 - 12:19 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Did you disconnect/move any grounds?
I'd check all your ground points. even take them off and remove the corrosion on all the ground points(sand under the mount)
sounds like a ground issue since battery is charged.
post Feb 8, 2009 - 11:35 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i really have a power problem. where are the grounds? i have the one on the passenger side connected, and i have one on the drivers side. and of course the battery grounds
post Feb 8, 2009 - 11:48 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
not the same engine, but the idea is the same. check out my post w/ all the pictures in particular
Thread
post Feb 9, 2009 - 4:46 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
aahhhh thanks for the link, ill have to check it at home. i cant see photobucket or imagestation at work frown.gif
post Feb 12, 2009 - 2:00 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
its alive! its alive! thanks to the man Dr Tweak...we narrowed it down to a missing ground. the strap on the harness on the back that bolts to the intake manifold. so let this be a lesson, dont forget that baby.
post Feb 12, 2009 - 7:01 AM
I like the valve cover, but i would have done the intake manifold a different color... just my 2psi
post Feb 12, 2009 - 11:16 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (lagos @ Feb 12, 2009 - 4:01 AM) *
hey no problem. im going to do the charge pipe the same and the turbo compressor housing. ill get the exhaust manifold ceramic coated too. that wil clean it up more.
post Feb 13, 2009 - 12:51 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (Smaay @ Feb 12, 2009 - 1:00 AM) *
sounded like a ground issue, but i was off in the location of the ground. sorry bro, glad its fixed!
Lo-Fi Version Time is now: December 4th, 2024 - 4:19 PM
