Just a quick laugh :P, wild question. |
Feb 7, 2009 - 9:00 PM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
while browsing the internet i came across this little humorous gem, figured you guys would enjoy.
http://wiki.answers.com/Q/Can_you_wire_a_5...97_chrysler_lhs " Question: Can you wire a 500w rms mono sub amp through the fuse box on a 97 chrysler lhs? Answer NO NO AND NO, an amp install kit is needed, and you need to tap at the battery. Dont even think about running this big wire through the door jamb, run it through an existing gromit in the firewall and fuse the wire (40-60 amp) within 12 inches of the battery. Disconnect the negative battery wire before you do anything. Ground the amp to solid frame (seatbelt or seat bolts and large ring connectors work well), if you dont, it will ground through the rca cables and make large amounts of smoke when you turn it on. " -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Feb 8, 2009 - 7:40 AM |
Enthusiast Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
If it can make you giggle more, some long time ago I wanted to install my amp with house wiring...Yea, solid core baby...
I know better now :0) -------------------- -Rémy 02 SiR, 08 250R |
Lo-Fi Version | Time is now: January 10th, 2025 - 9:04 PM |
