> Engine cleaning, opinions
post Feb 8, 2009 - 10:50 PM
92-gt
Joined Jan 22, '09
From Bremen
Ok, so I am needing to clean the engine in my ST.
I need to clean it inside and out.
When I took off my throttle body, I noticed quite a lot of carbon, so I can just imagine what the intake manifold etc. look like.
Also, it has a leaky valve cover gasket(new one is on its way), and it has 190k miles on it, so it needs a good cleaning.
What do you use for cleaning the engine, such as purple power etc.?
Also, what do you recommend for cleaning the inside of the engine? I have heard mixed reviews on stuff like seafoam, b12 chemtool, etc.
What do you guys recommend?
post Feb 9, 2009 - 12:04 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
just run good oil in it. cleaning this old of an engine might have bad effects (leaky seals, oil burning. cleaning away deposits keeping your oil in its proper place) which is why you hear bad things about seafoam and stuff.
what i do to clean the engine is buy some armor all, and go to the car wash, using the "tire && engine cleaner" or "bug remover" w/e its called there but its green, i spray the engine down really good, let it soak for a while, then spray it again, then switch over to high pressure soap, spray away at everything you see dirty, then rinse w/ the "wax" stuff. then you get the armor all and spray the WHOLE engine/bay/hoses down really well w/ the stuff. close the hood, and drive away. you will probably have a misfire, but it goes away in like 5 min of driving.
don't speay the distributor w/ any pressure. and i'm not responsible if you manage to mess something up., though i've done this for 3 years on 2 different celicas w/o an issue
post Feb 9, 2009 - 12:42 AM
92-gt
Joined Jan 22, '09
From Bremen
Yeah. I have heard stuff like that too. I just want to get rid of the carbon build up.
When pressure washing it like that, shouldnt you cover up electrical connectors and stuff, and leave it running?
Thanks.
post Feb 9, 2009 - 12:55 AM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
QUOTE (92-gt @ Feb 9, 2009 - 12:42 AM) *
Thanks.
no need to worry about wires, i worked at a detail shop and we use the " engine tire cleaner"
just spray it on there, they spray it off. make sure your car is off.
dont worry about the heat or anything ive done this to plenty of cars.
for the tough stuff, i used laquor** thinner. that stuff works wonders haha
post Feb 9, 2009 - 1:19 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (92-gt @ Feb 8, 2009 - 11:42 PM) *
Thanks.
i always leave it running, and never cover anything
post Feb 9, 2009 - 1:32 AM
92-gt
Joined Jan 22, '09
From Bremen
Do you know of anything that will clean the carbon out?
post Feb 9, 2009 - 10:29 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
carburetor cleaner, seafoam, deep creep (aerosol can of seafoam lol) or you can take the intake mani off and clean by hand, but expect that to take all day and remember where everything goes (vaccum lines mainly)
post Feb 9, 2009 - 10:55 AM
92-gt
Joined Jan 22, '09
From Bremen
Alright, thanks for your replies!
post Feb 9, 2009 - 11:09 AM
95st-celica
Joined Mar 29, '07
From Philly
i like to use seafoam for the inside of the engine, 1/2 can through a vac. line and the other half in the oil...do this right before and oil change as it thins your oil out...suck it up through a vac. line while your car is running...then put the rest in your oil and shut your car off for about 10 minutes...then start it up and drive it around...its gonna smoke real bad which is a good thing because its cleaning everything out really well...the best method for cleaning the outside of the motor/engine bay is to buy a can or 2 of gunk engine degreaser...spray it over everything...becarefull of the dis. i wouldnt spray it directly on any electronics...then take a pressure washer and pressure was all the **** out...that works best for me and i have had great resutls with it
1988 Dodge Aries K (sold)
post Feb 9, 2009 - 5:59 PM
92-gt
Joined Jan 22, '09
From Bremen
Thanks man! I appreciate the reply!
Lo-Fi Version Time is now: November 29th, 2024 - 2:22 PM
