Ebay Cold Air Intakes |
Feb 9, 2009 - 12:16 AM |
Enthusiast Joined Feb 8, '09 From Moscow, ID Currently Offline Reputation: 0 (0%) |
Hey guys,
So I have been looking for some time for a cold air intake (not a short ram) for my '94 GT. I keep coming across an intake made by chromeintakes on ebay. Is this a good buy or just more crap trying to make a buck off of me? Thanks! Here's a link to one of them: http://cgi.ebay.com/ebaymotors/_Car-Truck-...A1%7C240%3A1318 |
Feb 9, 2009 - 4:27 AM |
Enthusiast Joined Jan 10, '09 From Burtonsville, Maryland Currently Offline Reputation: 1 (100%) |
i bought that before.. its good.. but make sure you buy the one that comes with a K&N Filter.. i believe its only 20 or 30 bucks more.. it is definitly legit.
-------------------- THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma.. 6gc.net's outlaw vigilante because im a LEADER not a follower. |
Feb 10, 2009 - 3:04 PM |
Enthusiast Joined Dec 16, '07 From Virginia, U.S. Currently Offline Reputation: 1 (100%) |
yeah i bought one off of ebay also, they are definitely worth getting, 30 bucks shipped and you're good to go...dont spend like $200 on some injen intake that does the same thing as the 30 dollar one
Feb 10, 2009 - 4:25 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I got an intake a few months back from the same company, except it was a short ram, and i love it. it sounds great and it didn't break my bank:)
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Feb 23, 2009 - 2:05 AM |
Enthusiast Joined Feb 14, '08 From Shelbyville, TN Currently Offline Reputation: 0 (0%) |
I got one too - with the K&N filter - definitely worth it from seller chromeintakes! Beat $120 I have spent for an upgrade. Better than short ram and measureable and noticeable difference. I love hearing the "hiss" of the air sucking through the intake. Nice throaty sound. Expect a slight drop in fuel economy though (makes sense - more air = more fuel).
Feb 23, 2009 - 2:34 AM |
I got one too - with the K&N filter - definitely worth it from seller chromeintakes! Beat $120 I have spent for an upgrade. Better than short ram and measureable and noticeable difference. I love hearing the "hiss" of the air sucking through the intake. Nice throaty sound. Expect a slight drop in fuel economy though (makes sense - more air = more fuel). Thanks for the info! So do you have any pic's of how the pipe is routed in the engine bay? I am really interested on how they managed to get it to fit since things are so tight in that area. |
Feb 25, 2009 - 5:57 PM |
Enthusiast Joined Nov 29, '08 From Georgia Currently Offline Reputation: 0 (0%) |
OKay, I've been looking for something like this for my 94 celica gt. One question though. . . where does the filter end up??? And how does it fit in? Yesterday I put my stock box in, and my short ram out(just for a change) and it takes a lot of work to get things adjusted in there. Could someone please describe (not in huge detail) the installation??? Any problem areas?
I would love to get one but I want to know more about it first Thanks |
Feb 25, 2009 - 6:31 PM |
The filter ends up underneath the battery tray. It will fit - trust me - but it does require a little work - not bad though as I think I installed it in less than an hour. You have to remove the cruise control box - if equipped. The intake that I am referring to comes in 3 pieces. It's best, at least from my experience, to first install the piece that hooks to the throttle body, then assemble the piece with the filter. This is where it kinda gets tricky - because of the tight space underneath the battery you have to hold the piece with the filter in the general area of where it will be (underneath the battery) and connect it to the middle pipe. Once you have that piece assembled you can connect it to the pipe connected to the throttle body. You may have to do some manipulation of the pipes to get everything to align perfectly but it's not bad. As I stated I think I had mine installed in an hours time. I suggest that if you do have cruise control to place a small piece of foam pad, or any small piece of cushion material between the intake tube and the cruise control box. I did not do this initially and the result was that the intake tube vibrated against the cruise control box and became scratched up and eventually dug in to the intake tube. Of course it took a couple of months for this to happen but it's better to take preventive measures when you do the install. I can send you some pics if you like detailing what it looks like once installed - that may help you understand how it's done. Thanks.
Feb 25, 2009 - 6:39 PM |
pics would be great, is it still considered cold air when its under there?
This post has been edited by celicabob: Feb 25, 2009 - 7:24 PM |
Feb 25, 2009 - 6:51 PM |
pics would be great, under the battery tray, is it still considered cols air when its there? Oh hell yeah - way better than any short ram that sits at the top of the engine bay right under the hood. The placement of the filter ends up being right behind the two little cutouts in the splash guard on the bottom of your front end - look up unerneath your front end and you'll see what I'm talking about. You'll get colder air from there than you will anywhere else under the hood - not to mention that the cutouts allow air to flow directly at the filter. Here's the link for an auction on the one I have - http://cgi.ebay.com/ebaymotors/_Car-Truck-...A1%7C240%3A1318 |
Feb 25, 2009 - 6:55 PM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
Yeah just make sure you got a way to filter out water that gets in. I am going to look into these as well.
-------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Feb 25, 2009 - 7:01 PM |
Enthusiast Joined Jun 2, '08 From Fort Worth, Texas Currently Offline Reputation: 9 (100%) |
i had the intake, i like it but i got tired of the sound combined with my exhaust so i went back to stock.
but it is a genuine company that makes decent parts -------------------- |
Feb 25, 2009 - 7:05 PM |
Yeah just make sure you got a way to filter out water that gets in. I am going to look into these as well. To be honest with you I have never had that problem - and mine has been dropped 1.5" with Eibach Sportline springs! I originally thought about getting an AEM bypass that installs inline but didn't because I never exprience any problems with water - and believe me I've drove thru some deep puddles with no problems. i had the intake, i like it but i got tired of the sound combined with my exhaust so i went back to stock. but it is a genuine company that makes decent parts Yeah it is kinda loud - but I love that sound - not to mention that the gains are well worth dealing with the noise in my opinion. |
Feb 25, 2009 - 7:21 PM |
My short ram sounded like a weed-eater and actually, it sounds pretty awesome, but I'm sold on this one.
any comparisons on what this setup sounds like? This post has been edited by celicabob: Feb 25, 2009 - 7:23 PM |
Feb 25, 2009 - 7:26 PM |
My short ram sounded like a weed-eater and actually, it sounds pretty awesome, but I'm sold on this, woohoo! You'll be more than satisfied with the results. Trust me - this won't sound like a weed eater - you will hear a hiss coming from behind the driver fender/front tire - that's the intake sucking air. But you also get a deep throaty sound. Keep us posted. |
Feb 25, 2009 - 7:36 PM |
Enthusiast Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
bdawgbp1 please post setup of the cai and maybe a video too if possible. Thank you, im planning to get the same setup
Feb 25, 2009 - 8:01 PM |
Read further up this thread for some setup details. As far as installation you just remove your stock intake box - then begin with the instruction detailed above. Sorry no video as mine was installed a year ago. As far as resetting your ECU for the new changes there are some instructions in the how-to articles on doing this.
Feb 26, 2009 - 2:42 AM |
Sorry i meant post setup pictures
Feb 26, 2009 - 10:13 AM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
how many times can we have this topic?
jesus -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Mar 13, 2009 - 4:39 PM |
Enthusiast Joined Feb 23, '09 From Kahaluu, Hawaii Currently Offline Reputation: 0 (0%) |
I bought a Weapon R intake but my first inital choice was the cold air intake from chromeintakes on ebay because thats the only cold intake I could find. I searched high and low. Injen stopped making cold air for our cars LAST YEAR. Which completely sucked. I just wasn't sure about the ebay one and I heard some good reviews about the weapon r so I decided to try it. So far, its ok but I don't like the plastic sound when the air is going in. I think though I'm going to buy the cold air one and swap it out cause the current one is so short and close to the engine. I would rather have the cold air. However, being in Hawaii as well we have a lot of rain on my side of the island and water WAS the main concern. I found a JDM bypass valve for $9.99 off a site. I gotta look for it. I don't understand how it works though? how does it keep the water out? someone said it releases it thru the bypass valve.
Where does the filter go though? I saw two different posts. QUOTE The filter ends up underneath the battery tray. It will fit - trust me - but it does require a little work - not bad though as I think I installed it in less than an hour. You have to remove the cruise control box - if equipped. The intake that I am referring to comes in 3 pieces. It's best, at least from my experience, to first install the piece that hooks to the throttle body, then assemble the piece with the filter. This is where it kinda gets tricky - because of the tight space underneath the battery you have to hold the piece with the filter in the general area of where it will be (underneath the battery) and connect it to the middle pipe. Once you have that piece assembled you can connect it to the pipe connected to the throttle body. You may have to do some manipulation of the pipes to get everything to align perfectly but it's not bad. As I stated I think I had mine installed in an hours time. I suggest that if you do have cruise control to place a small piece of foam pad, or any small piece of cushion material between the intake tube and the cruise control box. I did not do this initially and the result was that the intake tube vibrated against the cruise control box and became scratched up and eventually dug in to the intake tube. Of course it took a couple of months for this to happen but it's better to take preventive measures when you do the install. I can send you some pics if you like detailing what it looks like once installed - that may help you understand how it's done. Thanks. And this one: QUOTE Oh hell yeah - way better than any short ram that sits at the top of the engine bay right under the hood. The placement of the filter ends up being right behind the two little cutouts in the splash guard on the bottom of your front end - look up unerneath your front end and you'll see what I'm talking about. You'll get colder air from there than you will anywhere else under the hood - not to mention that the cutouts allow air to flow directly at the filter. Here's the link for an auction on the one I have -------------------- ------------------------------------------------
808CELICA2DAMAX "May the Boost be with you..." [76 Celica GT LB /85 Celica GTS LB/94 Celica GT LB/87 Celica ST Cpe] 82 Datsun 280ZX / 82 Starlet / 78 Cressida / 03 Tacoma Pre-runner ------------------------------------------------ |
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:41 AM |
