> Celica wont stay running
post Feb 10, 2009 - 4:53 PM
kaslo
Joined Jul 15, '06
From Louisiana
I have a 1995 Celica GT with the 2.2 5fse. I am having an issues where it will turn over, start then die again. It will repeat this and wont stay running. We just replaced the distributor becuase we saw that one of the electrical inputs was busted. Any ideas on what it might be? we are thinking Igniter but not positive at this point.
post Feb 10, 2009 - 6:41 PM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
check ur fuel pump, thats what mine did when the pump went out, may also check ur fuel filter
post Feb 10, 2009 - 10:35 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
will it run if you hold the throttle a little?
post Feb 11, 2009 - 12:17 AM
kaslo
Joined Jul 15, '06
From Louisiana
QUOTE (mneal2_92788 @ Feb 10, 2009 - 7:41 PM) *
Just changed the fuel pump and its doing it but instead of dying instantly it sputters then dies. we are going to check the filter tomorrow.
and it will run with throttle open if it stays running long enuff for my to apply it.
post Feb 11, 2009 - 3:11 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (kaslo @ Feb 10, 2009 - 11:17 PM) *
Also check your idle air control, it could be dirty or malfunctioning. My 95 did the same thing where it wouldn't run on it's own but if I gave it gas it ran fine. Try spraying some carb cleaner in the little hole in front of the throttle plate in the intake while someone else keeps the car running.
1999 Celica GT
post Feb 15, 2009 - 4:31 PM
kaslo
Joined Jul 15, '06
From Louisiana
Ok so i have tried the different things, and my car will start and die. If i give it gas it will start and rev to 1500 rpms and then still die. Mechanic told me it acts like its not going into run mode which indicates an ECU issue. Anyone had this problem? its intermitent so sometimes it runs fine all day and other days i cant get it to start.
post Feb 15, 2009 - 5:20 PM
Bitter
Joined Mar 11, '06
if you hold the gas will it run? not just hold it and let go when it starts. i doubt its an ECU issue, sounds more like an ISC issue.
post Feb 15, 2009 - 5:28 PM
Rayme
Joined Feb 18, '06
From NB, Canada
Check your vacuum hose going to the map sensor.
-Rémy
02 SiR, 08 250R
post Feb 15, 2009 - 6:59 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
when it does run, does it miss? Do you have a lumpy idle? Test your coil to see if its in spec.
94 Celica gt white (sold)
post Feb 15, 2009 - 8:47 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
pop ur hood, look b the brake master cyl and find the box labled "diagnostics" open it and use a paperclip to bridge the terminals labled "B+" and "FP" listen to the fuel flow through the fuel rail ontop of your intake manifold. if its even and strong, the fuel pump isn't the issue. then try to start the car that way, if it runs fine, the problem is the COR
post Feb 16, 2009 - 12:14 PM
kaslo
Joined Jul 15, '06
From Louisiana
COR?
post Feb 16, 2009 - 1:39 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (kaslo @ Feb 16, 2009 - 11:14 AM) *
COR?
Circuit Opening Relay. Basically your fuel pump relay
post Feb 16, 2009 - 6:33 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
you might have a huge vacuume leak. check your hoses
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 17, 2009 - 1:47 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
the 5sfe and 7afe use maps. no matter how big of a vac leak you have it will still run. my 7a ran w/ the master cyl hose undone
post Feb 17, 2009 - 8:36 PM
Bitter
Joined Mar 11, '06
**** they'll start and run with the map sensors unhooked from the manifold!
post Feb 18, 2009 - 10:38 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE (Bitter @ Feb 17, 2009 - 7:36 PM) *
My 7a ran w/ no map, no tps, no O2 sensors, and a vac leak lol
post Feb 18, 2009 - 6:01 PM
silver6gc
Joined Aug 10, '08
From Raleigh, NC
I'm surprised that some of you guys that have responded didn't mention to CHECK THE CODES. I know from reading other posts at least two of you know how to do this. smile.gif
Trust me, I do this every day
post Feb 18, 2009 - 6:33 PM
kaslo
Joined Jul 15, '06
From Louisiana
Turns out the ecu is fried, pulled it out, opend the box and presto fried...so now i have to find a 89661-2d300 ECU for a 95 gt auto trany 2.2
post Feb 21, 2009 - 1:10 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
I would really try to find out what caused the ECU to fry before going any further.
post Feb 22, 2009 - 9:55 PM
kaslo
Joined Jul 15, '06
From Louisiana
it was the Distrubuter had a ****ed connecter that was broke and shorting out
Lo-Fi Version Time is now: February 19th, 2025 - 8:14 PM
