16 Pages V  « < 4 5 6 7 8 > »
> Operation: Boosted Tangerine, BACK UP AND RUNNING!!!
post Mar 24, 2009 - 8:03 AM
SeverX13
Joined Dec 4, '07
From Northeast Pennsylvania
UPDATE:
your update will be here friday.
This post has been edited by SeverX13: Mar 24, 2009 - 8:18 AM
‹Superaison› i'm a computer inclined guy..
‹Superaison› or girl. idk what gender I am anymore.
‹SeverX13› *facepalm*
suprakid: o sh!t
suprakid: i wanna get an obama chia pet
SeverX13: hahahahaha
post Mar 24, 2009 - 8:28 AM
Culpable04
Joined Apr 17, '06
From New Jersey
Keep up the good work guys.
post Mar 24, 2009 - 10:19 AM
keep truckin brent, cant wait for friday!
post Mar 24, 2009 - 10:20 AM
_Jim_
Joined Sep 22, '08
From Bergenfield
330whp 309ft/lbs @ 21 PSI
post Mar 24, 2009 - 10:26 AM
Cutrara
Joined May 6, '05
From PA
alcohol injection?? cool.... is that going on immediately or are you just trying to get everything working first.
post Mar 24, 2009 - 11:03 AM
it dont matter if it takes a day or a week, as long as they are doing it RIGHT, thats what matters, and im sure thats what they are doing.
stop the bickering, and stay on topic.
post Mar 24, 2009 - 2:55 PM
boosted185
Joined Aug 27, '07
From Summerville, SC
Thanks everyone for the positive support with this. Brent is doing great with this, its taking a little longer than we had expected, but it will be well worth the wait!!!
www.tweakdperformance.com
contact@tweakdperformance.com
post Mar 24, 2009 - 3:50 PM
supershannon77
Joined Jan 18, '07
From Bergen county NJ
awesome work but you should be driving this already Brenty ahahahahaha J/K
facebook WRC st205
post Mar 24, 2009 - 4:34 PM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
cant wait to see this come to life
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
post Mar 25, 2009 - 1:13 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (presure2 @ Mar 24, 2009 - 10:03 AM) *
QFT
Take your time - do it right. LMK when you get that special package wink.gif
This post has been edited by DEATH: Mar 25, 2009 - 1:14 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Mar 25, 2009 - 7:43 PM
6GenCelicaST
Joined Nov 15, '07
From Attleboro Mass
QUOTE (DEATH @ Mar 25, 2009 - 2:13 PM) *
QFT
Do I even want to know what that special package is?
Surprise buttsecks always works fine for me.
1977 Harley Sportser XLH
1992 Ford F-350 (plow truck)
Facebook
post Mar 26, 2009 - 11:45 AM
TRD_Ian
Joined Aug 19, '08
From New Brunswick
its dyno day! good luck boys! i wannna see some good numbers!
i hate snow, missing my celica
post Mar 27, 2009 - 10:38 AM
boosted95
Joined Apr 19, '07
From Dayton, Ohio
seen the massive intercooler and turbo both attached to the car, lookin great guys!
poopra sellout... 88targa, 50trim ct, 383lsd, and shreadin tires like its my job!!!
QUOTE (RUNNIN-LOW @ Feb 17, 2009 - 1:53 PM) *
buying a rusty car is like dating a girl with a bush! if u like it like that go for it.. :D if u can repair and make it look better then its all the better for u!...
post Mar 30, 2009 - 5:14 PM
supershannon77
Joined Jan 18, '07
updates?
facebook WRC st205
post Mar 30, 2009 - 7:17 PM
SeverX13
Joined Dec 4, '07
Ok, WOW. where to start.. last week on te 21st was when the build started. everything was goin good. we got into the garage got the bumper off and started takeing apart the exhaust manifold and such. the night went on and we really didnt get to much accomplished. we pulled the engine because we thought it would be a but easier and less time consuming. so we pulled the engine and started to get to the headgasket. the composite one i has was SHOT. i wouldnt have lasted long if i kept it. so we put the metal headgasket on and started witht he flywheel and clucth. i used a stage 4 clucth from doctor tweak. which is amazing. we ran into SEVERAL problems. 1st big problem was the injectors. i cant find this anywhere on 6gc. but. YOU MUST GET 460cc HIGH IMPEDANCE INJECTORS. check the part number b4 you buy, if the last 4 digits are 1350 DO NOT BUY. cant stress it enough. the part number you want is 2010. i cant thank DEATH enough for sending me those injectors. those injectors are a BITCH to take out so make sure ur right the 1st time haha.
tuesday night we attemped to do a mock up on the turboa dn wastegate. but of course. another problem arose. the wastgate woldnt fit due to the oil filter. SO what we did was order a relocation kit fomr the local shop. thinkin we were golden..another problem. oil filter relocation still got in the was of the waste gate. BUT it came with this small threaded peice that we screwed into the filter and removed the oil cooler and spun the bitch down. wastegate fitted pretty good but im still gonna have to take it off to cahnge the filter. as if all that wasnt enough, the night b4 the estimated dyno date while installing the oil lines, the fukcin oil reducer snapped when it was being tightend. it was some cheap ass cast metal. so i spent a good 30 minuted rumageing thru the shop tryin to find somethin that would work for an oil line. i rigged somethin up for the time being. we got the I/C piping all welded up and fitted on REAL nice. gotta thank me and cams friend joey for putting some nice beads on the piping.
so now its dyno day. or so we thought. we got everything bolted up and connected and decided to start it so we can see what problems we had. well. we tried starting and it would turn over but not start. from tehre we started eliminating problems. spark was fine, fuel was going through, but the problem was it was putting to much fuel into it which extinguished the spark. so we went to take fuel away with the SAFC. turned the car to the on postion and the MF'in SAFC would turn on. so we said ok maybe the wireing was wrong. gotta be. checked it thouroghly. and nope not a problem with wires. we then tried to give it direct power form the battery. and of course, still no fukcin luck. we called shannon and talked to her and jim. she said they had an SAFC layin around and what we could do is come down friday and get it wired up and dynod. so thats what we PLANNED for. and in operation boosted tangerine... nothing goes as planned lol
so we drove to jim and shannons and got the SAFC hooked up and the celi off the trailor. jim put in shannons numbers from her car. well jim tried crankin her over and we got nothin. so stevenson and jim played around with the timing and still we got nothing. we tried for about 5 hours. i had to be in exton pennyslvanis for a meeting at UTI se we left arlund 3am from jersey with the celica in jims driveway.
saturday came and i went to the meeting then headed up to jim and shannons place. we didnt get started until dark. we started eliminating problems. one by one we narrowed it down. played witht he timing more and such. switch the map sensors and then the bitch fired up! that got me pumped. another problem we encounterd was that the safc wasnt responding to some of the changes. i was runnin 50% fuel. which it should have been around 30%. i kno im forgeting some stuff so cut me a break haha. but we got it running and drove it around the block last night. so today and tomorrow jim is tuning it and workin some small items. so tomorrow or wednesday i should be pickin it up and having my boosted tangerine. I cant thank everyone enough for helping me out. more updates later to come
This post has been edited by SeverX13: Apr 1, 2009 - 9:16 AM
suprakid: o sh!t
post Mar 30, 2009 - 7:21 PM
good to hear your up and running brent!
sorry about the map sensor, a replacement is being overnighted tommorow.
the info for the right injectors is right in my profile, and in my build thread. wink.gif
post Mar 30, 2009 - 7:29 PM
SeverX13
Joined Dec 4, '07
QUOTE (presure2 @ Mar 30, 2009 - 7:21 PM) *
BTW manny. im the 1st t3/t4 5sfte to have A/C!!!! lol
suprakid: o sh!t
post Mar 30, 2009 - 7:36 PM
QUOTE (SeverX13 @ Mar 30, 2009 - 7:29 PM) *
good job!
howd you mount your oil filter?
pics?
post Mar 30, 2009 - 7:37 PM
SeverX13
Joined Dec 4, '07
haha its under the wastegate. im gonna have to take off the wastegate to change it
suprakid: o sh!t
Lo-Fi Version Time is now: November 27th, 2024 - 5:43 AM
