> Throttle body spacer
post Feb 13, 2009 - 12:57 PM
Nyczroflz
Joined Feb 7, '08
From Queens, New York
Apparently my TSX friend told about this new craze over the throttle body spacer. Its suppose to give u more hp n tq n saves gas. I think its garbage but he says hes getting gains off of it. There are ones made for the 5sfe but none for the 7afe kindasad.gif Do any of u guys use it or heard of it? the one he has is made by p2r.
sig removed. too big.
post Feb 13, 2009 - 10:28 PM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
rubbish
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Feb 16, 2009 - 1:29 AM
6strngs
Joined May 12, '06
From Wilmington, NC
if you had a carburator, sure, it's not going to do anything for an EFI vehicle where the air and fuel aren't mixed until just before combustion chamer.
post Feb 16, 2009 - 6:01 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Wow, I want shiney red on my engine, would look cool, or something
PS. I've tried the Simota Super Spiral Turbo Ventilator (whatever you call it with 100 redundant words in the product name)... Another gas saver/just add torque mod/whatever
These things have no positive benefits... And the ones with blades or jagged cut teeth or basically anything that reduces the total diameter or area of the intake line will act as an intake restrictor and reduce total max HP aswell as detriment Off-Idle throttle response.
The throttle body spacer will increase the total volume of the intake manifold but you need some other mods to be able to fill that volume, the engine itself isn't going to recognise there's a bigger chamber of air to breathe from and somehow suck harder?
This post has been edited by delusionz: Feb 16, 2009 - 6:15 AM
Mike W
269awhp / 273ft-lbs
post Feb 23, 2009 - 12:00 AM
bdawgbp1
Joined Feb 14, '08
From Shelbyville, TN
I was wandering the same thing myself - is it worth spending money on? What do you need to benefit from the bigger volume? Would you benefit with just a cold air intake with K&N filter? Do you need a piggyback power module such as the Venom 400? This was an upgrade I wasn considering but am very hesitant as I haven't really heard of these much on fuel injected as I have with carbeurated. thanks.
post Mar 3, 2009 - 4:50 AM
delusionz
Joined Feb 11, '08
Those mods are nothing like the carby slider, which was a fix for a poor design of the throttle mechanisms and the shape of the carburetor. Fuel injection and plenum is a far superior design.
From the throttle body back, the size of the plenum correlates to the air needs of the engine and the size of the valves, etc. It's all been calculated, there's nothing but detriment when it's been ****ed with as it throws off the proportions of everything else. The only things that are good for the intake are 1. forcing more air in, 2. getting colder air in, 3. allowing the engine to breathe through a less restrictive filter.
Mike W
269awhp / 273ft-lbs
post Mar 3, 2009 - 11:31 AM
bdawgbp1
Joined Feb 14, '08
Cool beans - that's kind of what I thought. In short the throttle body spacer would just be a waste of time and money and will not show any gains at all except for possibly throwing the system off? I already have a CAI with K&N filter. As far as forcing more air into the system the only way to do that would be turbo or supercharger - correct? Thanks for your input. biggrin.gif
post Mar 4, 2009 - 4:34 PM
caszboy
Joined Jun 16, '08
From va beach
They make good paper weights! I know, i use one on my desk. They only benefit top mount carbs. Save the $50 for gas and a go-fast sticker (gas savings and +HP!)
But for real, don't buy one unless you want a spray bar for N2O.
This post has been edited by caszboy: Mar 4, 2009 - 4:40 PM
post Mar 4, 2009 - 7:06 PM
bdawgbp1
Joined Feb 14, '08
Thanks - I was about to waste about $90 on one off of eBay - check out the listing: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=250253732870. They hype it up like you can get some real power gains + fuel economy. smile.gif
Lo-Fi Version Time is now: November 26th, 2024 - 7:05 PM
