D0W3RK Finally Turbo!, New Intercooler |
Feb 14, 2009 - 12:50 AM |
Enthusiast Joined Jun 10, '08 From Virginia beach Currently Offline Reputation: 8 (100%) |
so after a lot of wait and gathering of parts... that car is Boosted. dyno sheet will be up when i can scan it. but it did 160 to the wheels on 5lbs. had to stop before it kept going higher due to Boost creeping. :-\ but ill have pics up and dyno soon!!
feels great thanks for all the help everyone who has given me advice and parts along the way!! -Allen and now my next step is to restore those blue radiator hoses and stuff to black. blue looks so .... yea. haha This post has been edited by d0w0rkS0n: Apr 2, 2009 - 11:25 AM -------------------- |
Feb 14, 2009 - 1:41 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Pics or I call BS
-------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Feb 14, 2009 - 10:40 AM |
haha dont worry Tweak. im at work. get off at 7. Pics will be up Tonight.
Feb 15, 2009 - 7:17 PM |
ok..posted pics. now i just need to get a copy of my dyno on the comp.
Feb 15, 2009 - 7:25 PM |
great work.
what PSI do you plan to take it ? don't tell me you did all this work for 5 PSI only. -------------------- |
Feb 15, 2009 - 8:14 PM |
thanks! and hell no im not just trying to stay at 5psi. lol. lookin for 12.
Feb 16, 2009 - 10:33 AM |
post a list of all the mods you did
Feb 16, 2009 - 10:42 AM |
looks good.
like the top mount turbo setup, curious as to why you mounted it with the compressor on the passanger side? -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Feb 16, 2009 - 12:49 PM |
Enthusiast Joined Mar 28, '08 From Washignton Currently Offline Reputation: 1 (100%) |
looks good. like the top mount turbo setup, curious as to why you mounted it with the compressor on the passanger side? X2 ThoughI would imagine for FMIC it may be a little less piping. -Terracar -------------------- '92 ST185, '88 ST165, '05 Galant LS, '08 Legacy
Feb 16, 2009 - 1:27 PM |
thats exactly why it was mounted on the compressor side. just made the piping layout easier and more accessible.
Feb 16, 2009 - 1:37 PM |
Mods are:
460cc Denso Injectors. 255lph Walboro Fuel Pump T3/T4 "ebay Special" turbo. .57 trim Internally Wastegated with 6psi spring. 2.5" IC piping. Big Greddy FMIC Apexi Neo HKS SSQV as of 1 hour ago. Apexi Turbo Timer custom 2.5" downpipe 2.5" full exhaust JGS Tools Oil feed and drain kit -------------------- |
Feb 16, 2009 - 2:00 PM |
Mods are: 460cc Denso Injectors. 255lph Walboro Fuel Pump T3/T4 "ebay Special" turbo. .57 trim Internally Wastegated with 6psi spring. 2.5" IC piping. Big Greddy FMIC Apexi Neo HKS SSQV as of 1 hour ago. Apexi Turbo Timer custom 2.5" downpipe 2.5" full exhaust JGS Tools Oil feed and drain kit I guess this explains why you're getting boost creep at 5 psi. -------------------- |
Feb 16, 2009 - 2:36 PM |
Enthusiast Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) |
looks good man keep it up!! update with dyno sheets please!!
Feb 16, 2009 - 2:54 PM |
Mods are: 460cc Denso Injectors. 255lph Walboro Fuel Pump T3/T4 "ebay Special" turbo. .57 trim Internally Wastegated with 6psi spring. 2.5" IC piping. Big Greddy FMIC Apexi Neo HKS SSQV as of 1 hour ago. Apexi Turbo Timer custom 2.5" downpipe 2.5" full exhaust JGS Tools Oil feed and drain kit I guess this explains why you're getting boost creep at 5 psi. but it creeps all the way to 12psi -------------------- |
Feb 16, 2009 - 3:01 PM |
Thats what happens on internal waste gates with free flowing exhausts.
Feb 16, 2009 - 5:07 PM |
so i either need to Bore out the whole in the wastegate more, or buy a lower spring if im not mistaken
Feb 16, 2009 - 6:22 PM |
no, tune it for 12psi. 5 pounds gets old quick.
Feb 16, 2009 - 6:25 PM |
i was thinkin about that, but i wasnt sure what the situation would be. if it woul still creep higher and higher.
Feb 16, 2009 - 7:13 PM |
I have the same boost creep problem. I have an internally wastegated turbo with an 11psi spring (it's the smallest I could find for my turbo) and it creeps to about 15psi. I'm sure it'll creep higher than that but my MAP sensor won't let it. I plan on getting a Tial external wastegate with a 7 or 8psi spring and turn it up to 10psi. Hopefully that will help the creep issue, if not I'll be in the market for a new turbo with a bigger exhaust housing.
This post has been edited by hurley97: Feb 16, 2009 - 7:14 PM -------------------- |
Feb 17, 2009 - 10:12 PM |
yea i actually just took apart my buddys old t3/t4 turbo that has the same exhaust housing as mine. im gonna take a dremel to the hole for the wastegate and open it up some more. *according to my tuner, that will help with the boost creep* but im orderin my MBC in a few. so ill get that and turn down the boost for now.
Lo-Fi Version | Time is now: November 27th, 2024 - 9:40 AM |
