> miss/hesitation, 3k rpm miss/hesitation
post Feb 14, 2009 - 2:49 PM
darranst205
Joined Jun 8, '08
From kerry ireland
hey everybody let me start by saying my car is a jdm import st205wrc with the 3s-gte engine
i live in ireland and always run 99ron fuel
my problem is a bit of a odd one to me im getting a miss/hesitation around 3k rpm but not when cold or hot
but when its been parked for around ten min after driven and then go driven again and its only there a few
min and goes away again
iv put in a new fuel pump, dizzy cap, rotar arm, leads, fuel filter all from Mr T ngk plugs no7 iriduim and platinum
and checked the timing and all vac pipes
has anyone here even come across this before my only other option after this is take it to Ttec
post Feb 14, 2009 - 3:17 PM
Only thing I can think of is perhaps you need to replace the coolant temp sensor.
post Feb 18, 2009 - 4:02 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
re-check spark plugs and wires. check for air leaks after the turbo. when this happens, see what the OEM boost gauge is showing. probably AFM is malfunctioning. you can do voltage test on the AFM (if you`re not using map sensor).
i`m not sure, but maybe fuel filter kindasad.gif its a good idea to replace it anyway smile.gif
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post Feb 21, 2009 - 3:25 AM
darranst205
Joined Jun 8, '08
From kerry ireland
ok so where exactly is the coolant leval sensor
"AFM is malfunctioning. you can do voltage test on the AFM (if you`re not using map sensor).
i`m not sure, but maybe fuel filter"
st205 run map sensor from factory and i have a new fuel filter in already
post Feb 24, 2009 - 1:09 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
coolant temp sensor...its located on the coolant neck on the engine
Lo-Fi Version Time is now: April 22nd, 2025 - 7:21 AM
