Installing a Neon light in the trunk |
Feb 14, 2009 - 10:40 PM |
Enthusiast Joined Feb 5, '09 From New Zealand Currently Offline Reputation: 0 (0%) |
For the purposes of not confusing any Americans that will read this, I will be referring to my boot as a 'trunk'.
The sub boxes I am currently finishing off will partially cover the current trunk light. So I decided to install a neon light i've had hanging around for a while, bought it on clearance. I wanted it to come on when I open the trunk, just like the light that's already there. You should disconnect the battery when you are soldering, in case the 12V shorts through your soldering iron etc, I didn't and my fuses were fine, but it's not worth the risk. First I pryed out the current light with a flat head screwdriver. Testing the connections with a multimeter I found that the blue/yellow wire was 12V, and the red/blue wire was ground. The 12V is connected to one side of the bulb (circled in red), and the ground is connected through the switch to the other side of the bulb (circled in blue). This is where you want to connect the power for the neon light, this way it will work only when the trunk is open, and the switch is on. I found it was too difficult to solder to the little rivet like things, so the negative was soldered to the wire that is crimped to the blue circled thingy, and the positive was soldered to the blue/yellow wire (and wrapped with electricians tape). Please note the connector flips over before plugging in, otherwise it looks like I'm just connecting it across the switch, which wouldn't work. After pic: Should be good at night when unloading groceries. |
Feb 14, 2009 - 11:55 PM |
Enthusiast Joined Aug 2, '06 From bay area Currently Offline Reputation: 21 (100%) |
can we get nite pics if u dont mind
Feb 15, 2009 - 12:02 AM |
OMG, I can't win! lol
I just did this today, and it's still day light over here in kiwi-land. Will try and remember tonight. |
Feb 15, 2009 - 4:29 AM |
Yay, it's 10:30pm and my memory held up ok.
Night pic: This post has been edited by korban: Feb 15, 2009 - 4:31 AM |
Feb 15, 2009 - 2:26 PM |
Enthusiast Joined Oct 2, '08 From New Zealand Currently Offline Reputation: 0 (0%) |
WOW Cool ma that looks Awsome.
-------------------- WWSideWinder - 1996 - 3S-FE - Auckland New Zealand
~ signature made by jaws4god ~ Have a look at my thread for updates on my progress. "http://www.6gc.net/forums/index.php?showtopic=63338&hl=0" |
Feb 15, 2009 - 6:41 PM |
Nice! I just did something like this a couple of weeks ago, since my trunk light never has worked. Except I used LED's and drilled them into the sides of the trunk.
Feb 16, 2009 - 2:19 AM |
Enthusiast Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
Nice! I just did something like this a couple of weeks ago, since my trunk light never has worked. Except I used LED's and drilled them into the sides of the trunk. Let's see! -------------------- "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Lo-Fi Version | Time is now: January 11th, 2025 - 1:21 AM |
