> Hade this proble for about a month...., Now im starting to hate it....
post Oct 9, 2003 - 2:30 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
Everything started then i changed my fuel filter. First, in the shop they sad how much dose it cost (50$ for the F****** fuel filter!!!!) so i bout fuel filter from corolla and it is a little bit different then the celica's (difference is that corolla folter dosnt has a tighten bolt at the inlet, it has just a pipe, on with the fuel tube puts on), so i made some modification that new filter fitted well, and took my car for a test drive (car felt MORE alive then ever). BUT then i flored it in the first gear and got my RPM on about 6800 and swithed in the second gear i got HUGE back fire.... At first i was kinda happy biggrin.gif That back fire even pushed off my rear can silencer (i hade to look for it in the bushes for a 15 min biggrin.gif biggrin.gif), But now almost everytime i flor my car on high RPM i got that f***** back fire then swithing in to secon gear and in to 3 gear... Especialy then weather is cold. Ok i know, that im running RICH thats why i got that back fire, but i tryed to adjust my S-AFC setting, but then i lean a little bit there is no back fire, but my car feels more like laizy. And as you know troble is NOT walking alone biggrin.gif there is some other thing that i hade... Then i flor and swith my gear near some 4800 rpm i got somthing like a 1 sec lag, my car just stals and then i get power again, but this only hapens then i swith from 1 to 2 ... What the F this could be, cuz it is starting to get on my nervs... So anyone, make a sugestion.
Thanks
<<<<<< DCw / JDMart >>>>>>>
post Oct 9, 2003 - 9:22 AM
doGGy
Joined Oct 28, '02
So, anyone? Any sugestions?
post Oct 9, 2003 - 10:41 AM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
only thing i can figure out is the problem is caused by having the wrong fuel filter. other than that, i don't know what could be causing that.
how low do you have to set the curve on your AFC to get it lean enough to stop from doing that?
post Oct 9, 2003 - 10:56 AM
doGGy
Joined Oct 28, '02
QUOTE (Delta_Phoenix @ Oct 9, 2003 - 8:41 AM)
On high trotle on 6000 rpm about -10 -8 and it stops firing... Fuel filter is just the same size same everything, only the inlet fixing is different...
Lo-Fi Version Time is now: February 21st, 2025 - 1:58 PM
