wheel bearing pside front, how to get to it |
Feb 15, 2009 - 4:52 PM |
Enthusiast Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
hi there guys, ive been told i have a bad wheel bearing so, im just wondering how 2 get 2 it. I have the car up and the front p side wheel off. then i come 2 this odd shaped nut with like 20 teeth and a clip on it (splitpin?) which im unsure how to remove, i dont wanna just plow ahead and get it off the wrong way.
also with the wheel bearing I understand that ill have to get it hydrolicly (sp) popped out and pressed in? and auto shop should be able 2 do this right? cheers lads any help much appreciated. |
Feb 15, 2009 - 7:29 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
I think your talking about the castle nut and the cotter pin? Its not that hard really, but your probly gonna have to take it into a shop and have them use an arbor press to get that bearing set in there. But check out the search feature, I found this for you.....bearing removal
Lo-Fi Version | Time is now: November 27th, 2024 - 2:47 AM |
