Mike's ST205 GT4 build thread, update: tuned to 200kw |
Oct 9, 2012 - 7:01 AM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
understandable, it would make sense keep the stock cam and head for low end torque as a mild or upgraded cam would give you more power up top.
with the 28rs, when is the turbo fully spooled? the ct's is around 3500rpms, curious to know the power band difference between the two. -------------------- st205 powered ss3 coupe
Oct 9, 2012 - 8:08 AM |
yeah, long gears and heavy weight
spooling range is between 2200 and 2800 with about 15psi , from 3500 to the redline you can have anything up to 25psi -------------------- Mike W
Oct 25, 2012 - 1:35 AM |
some new handling bits
GAB front strut brace and Nolathane front swaybar bushes. Unfortunately the swaybar bushes were too big to use we they were 20mm and my stock sway bar is 16mm? Whiteline adjustable rear swaybar new D bushes for rear swaybar -------------------- Mike W
Oct 25, 2012 - 3:06 AM |
Enthusiast Joined Apr 30, '12 From Wellington, NZ Currently Offline Reputation: 0 (0%) |
Excellent purchases!
What kind of rear sway bar are you rolling with? |
Oct 25, 2012 - 8:54 AM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
nice stuff mike glad to see you posting again!
Oct 26, 2012 - 3:50 AM |
This car just keeps breaking, a bolt rattled out from the timing cover backing plate and shredded my cam belt, my alternator just died from trying to run with a flat battery that was my fault today....
Im running factory sway bars, all i have is BC coilovers, I got the bushes for the front to fix annoying squeeking and found they were the wrong size... so i returned them (but i managed to use their greese to fix my squeeky factory D bushes) and they convinced me to buy a rear sway bar lol -------------------- Mike W
Oct 26, 2012 - 3:55 AM |
from the looks of it, it doesnt look like theres any sense upgrading the end links, even though they are skinny, the coilovers are aluminum, the mounting tab for the end link is aluminum and is just like 4mm thick tig welded on, the tab would break off the coilover before the factory endlink ever succumbed to stress...
the improvement comes from how much lift off you select with the 3 holes on the end. -------------------- Mike W
Oct 26, 2012 - 12:23 PM |
you could of asked us that!! I even knew its 15mm sway bar size for the front. Its posted on the superstrut suspension thread that stickied. THe ss-III sway bars are 14mm.
The stock GT ST204 mcpherson sway bars are 20mm front and 16mm rear. a cmon you cant be serious about the rear end link. the tabs would not break. that only happens on the front mcpherson suspension like the pic I posted This post has been edited by BonzaiCelica: Oct 26, 2012 - 12:25 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 26, 2012 - 1:56 PM |
^ He is having torque shoved to his rear wheels too though, so it doesn't apply the same as with a FWD Celi.
'93 MX-5 LE |
Oct 26, 2012 - 5:19 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
real sorry to hear your having issues, but that whiteline swaybar looks good
Oct 27, 2012 - 4:37 AM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
some new handling bits GAB front strut brace and Nolathane front swaybar bushes. Unfortunately the swaybar bushes were too big to use we they were 20mm and my stock sway bar is 16mm? What sway bar did you get? the adj. or non adj one? -------------------- (\__/)
Oct 28, 2012 - 3:21 AM |
sorry i didnt take the swaybar out of the packaging yet, have been busy with moving house and issues with the car,
the brand is Whiteline which is made in Australia and is the major manufacturer of Non-Chinese chassis stiffening components in this region (New Zealand and Australia etc) as you can see in the photo the end is hanging out with 3 holes on the end, with the hole on one end being most lift off and the hole on the other end being least lift-off, i plan to just start in the middle and see if theres any change at all then play with the other settings. also, the major brand of polyurethane products in this area is Nolathane. They listed a part number for D bushes too big for ST205 Celica GT-Four unfortunately they ****ed up by having an incorrect database -------------------- Mike W
Oct 28, 2012 - 5:47 PM |
Dec 13, 2012 - 5:05 PM |
Tuned to 200 kilowatts, injectors maxed
blue line is on 0.8bar wastegate spring pressure, pink line is with a bleed-off boost tap which spiked up to 1.5bar and dropped back to 1.2bar -------------------- Mike W
Dec 13, 2012 - 7:35 PM |
So, what is that in American...? *meanders over to Google*
OHHH, you mean 268.2hp. Nice. -------------------- 2001 Miata LS 5-speed
Dec 14, 2012 - 12:33 AM |
nice numbers there, congrates anything next on the cards? -------------------- |
Dec 14, 2012 - 2:34 PM |
Ahh just little bits now, I need the hand controller for my power fc and some water temp and oil press gauges, i definitely need an electronic boost controller.
I got nowhere to go from here, power wise. injectors are maxed,turbo wont put out much more -------------------- Mike W
Dec 14, 2012 - 10:17 PM |
Where to from here? Do a heli.
You'll be mad happy with 200wkw, just drive it for a while, then decide if you need more. |
Dec 31, 2012 - 5:54 PM |
1200 cc injectors and switch to ethanol advance timing
i've had **** luck with my car too...dead alt from skinny negative. and other stupid problems.... -------------------- |
Jan 6, 2013 - 4:20 AM |
got water temp now
some pics from dyno tune welding in o2 bung on the dyno time attack evo that was there time attack evo -------------------- Mike W
Lo-Fi Version | Time is now: November 30th, 2024 - 6:36 AM |
