Mike's ST205 GT4 build thread, update: tuned to 200kw |
Oct 19, 2009 - 4:16 AM |
So once again, I've flushed my cooling system... This is getting annoying...
Yesterday I tried to get the thermostat job done, didn't have the right tools to get the thermostat housing off so just made do with a flush. My heater was working better after that but my engine temperature was dropping very low (less than 1/4) at speeds over 80kph. Today I tried again, this time I got the thermostat housing off, I had to remove the radiator and push the fuse boxes to the side. I flushed the system with the garden hose and installed the new Toyota Genuine thermostat (82 deg C) and rubber O ring seal, put it all back together and filled it with 2.5L of coolant, the topped up the rest with water. Fired up the engine with the heater running and kept topping up the water until full. The result, engine got up to temp as normal, checked for leaks - no leaks so far, but heater has no hot air at all??? It's now 10pm at night so I called it a day, didn't go out for a test drive incase I get stuck. Will see what happens tomorrow. I checked my diagnostic codes by shorting TE1 and E1 in the diagnostic box and turning the key to "ON" without starting it. I had error code 34 (fuel cut due to excessive boost -- already knew it was overboosting) and error code 54 (intercooler water pump or low intercooler level -- this comes up all the time, just top up the cooler and clear the codes). Hopefully everything comes right tomorrow... -------------------- Mike W
Oct 19, 2009 - 9:41 AM |
Enthusiast Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
Is there somewhere online I can buy an intake like yours? or was it a local source? It's just a DIY with a K&N. 3" stainless steel pipe (easiest to get from ebay) 3x 3" hose clamps (from auto parts store), 3" silicone joiner (from performance parts store) K&N filter (ebay or performance parts store, these are expensive so try find a good deal) Also you'll need 2 mini filters, IIRC the top one was 19mm (oil breather) and the bottom one (idler breather) was 15mm. This setup is far from ideal anyways, It runs like **** but it sounds cool. It's better to have the bov return the air down the throat of the turbo, or atleast get a 50/50 split of atmo and plumb back, I just don't have the welding tools or skills to do that so my intake is still an ongoing project. I think Apexi have an ST205/ST215 kit that has the bov return flange on it, I've seen it on some cars, thats the ideal way. EDIT: Sorry it's Blitz here's what I'm talking about QUOTE POLSIHED ST205 GT4 HKS/BLITZ INTAKE SYSTEM New postby jap-spec-performance on 19 Aug 2009 21:54 ST205 GT4 POLISHED BLITZ/HKS INTAKE SYSTEM, THIS WAS ON OUR TUNER CAR WHEN IT ARRIVED AND WE GAVE IT A QUICK POLISH FOR THAT LITTLE EXTRA BLING IN THE ENGINE BAY. THE FILTER HAS BEEN OUT CHECKED AND CLEANED. £60 ono + P&P very good, thanks for the info -------------------- ST205 Crew represent
Challenge Accepted |
Oct 21, 2009 - 11:53 PM |
Oct 22, 2009 - 12:03 AM |
The new thermostat is going well, No matter what the conditions my engine temperature is maintaining the right temp and my heater is working, even when the car is moving!
Here's a video of the old thermostat though, I can't figure out whats wrong with it, It opens in a container of hot water and it closes under cold water. -------------------- Mike W
Oct 22, 2009 - 12:45 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
didn't your radiator get fixed. might be a fault in ther??? blockage or air bubbles else where?
This post has been edited by Rusty: Oct 22, 2009 - 12:45 AM -------------------- |
Oct 22, 2009 - 1:52 AM |
The new thermostat fixed my engine operating temp problem and my heater, all is fine now.
I just don't understand what is wrong with the old one, aside from it looks like crap. It doesn't open under luke warm water or cold water, it just opens in boiling water which is how it should be. Maybe all it needed was a good clearing out with everything removed? -------------------- Mike W
Oct 22, 2009 - 9:48 AM |
air bubbles in the system will cause all sorts of weird problems. It could very well be that just opening everything up and flushing again fixed your problem rather than changing the 'stat. Next time you drain the coolant though you need to jack the front end of the car way up when you refill the system....this allows any air bubbles to escape as the rad fill tube will then be the highest point. Just FYI
Oct 23, 2009 - 1:11 AM |
on a completely different note whats the size for your space saver in your boot?
Oct 23, 2009 - 5:07 PM |
on a completely different note whats the size for your space saver in your boot? T125/70D17 -------------------- Mike W
Nov 12, 2009 - 9:15 PM |
This post has been edited by delusionz: Apr 21, 2012 - 3:07 AM -------------------- Mike W
Nov 12, 2009 - 9:29 PM |
At first I thought you meant cleaning...I was like that's still dirty as hell!
Nice touches though, it would be nice if someone made faux-aluminum dash trim. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Nov 12, 2009 - 10:06 PM |
Hehe yeah needs a vacuum, The aluminum painted trims is what I've finished off.
I got bored with all black, esp since the door sill and the gear knob are silver / aluminum. I'm happy with it the way it is now, I didn't want to get carried away with it, as I've seen in other interiors where they've painted too much. -------------------- Mike W
Nov 12, 2009 - 10:07 PM |
I would probably only do the door handle, switch bezel, and radio bezel. How did you do the gauge trim though? And how did you paint everything else, actually? Looks very good!
'93 MX-5 LE |
Nov 12, 2009 - 10:16 PM |
The gauge trim is the 2nd layer behind the clear plastic screen.
Nov 13, 2009 - 12:20 AM |
looks tidy bro , hope you used good stuff so it doesn't chip off, and waste all your good work. Yeah theres a line, from tidy up some areas to looking like the ex has emptyed a paint tin in the car.
+1 for a vacuum -------------------- |
Nov 13, 2009 - 12:28 AM |
And I'm wondering how your door panels got warped...right in front of the handle. Looks like there are tiny dents/impressions.
This post has been edited by SwissFerdi: Nov 13, 2009 - 12:29 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Nov 13, 2009 - 4:53 AM |
The door card was like that when i bought the car. I presume someone before me drove with the windows down in the rain.
Nov 26, 2009 - 9:49 PM |
Our SS-III and GT-Four Celicas after some waxing.
This post has been edited by delusionz: Nov 26, 2009 - 9:51 PM -------------------- Mike W
Nov 26, 2009 - 11:19 PM |
ahh nice and clean
Nov 29, 2009 - 2:41 AM |
Enthusiast Joined Nov 27, '09 From New Zealand Currently Offline Reputation: 1 (100%) |
wow dude 2 Celica's and the best of the best as well :-)
I *almost* considered this SSIII on trademe But the fact that it was 1) Out of town 2) More expensive 3) Not a red GT4 (lol) swayed me away from it. But still, super low k's and looks mint.. How "different" are the SS3 and GT4 to drive? I expect the extra power and AWD makes the GT4 quite a different beast.. |
Lo-Fi Version | Time is now: November 30th, 2024 - 4:34 AM |
