> stereo issues?, problems with the acc.
post Feb 18, 2009 - 9:10 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i recently ran into a problem with my stereo (the deh-6900ub, by pioneer). first off i need to say that i wired it into the fuses. i did this over a year ago and suddenly it reset on me every time the car i turned off and the circuit is broken. i have the acc tapped into the 15a stop fuse, or maybe the ecu... i forget, but both of these are a circuit that remains unbroken when the car is turned off. my 12v yellow power wire is tapped into the cig/radio 15a fuse. the problem is that every time the car is turned off and the electrical circuit is broken all of my settings are lost. i even ran a new wire to connect the acc with. can anyone figure this issue out?
post Feb 18, 2009 - 10:07 PM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
QUOTE (garin @ Feb 18, 2009 - 10:10 PM) *
just curious, why didn't you just wire it to the 12v wire that plugs into the back of the CD player?
post Feb 18, 2009 - 10:09 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
not sure what you mean... but the acc has to be connected to something that is in constant circuit. the acc and the 12v are both connected to the battery... can you explain what you mean?... thanks
post Feb 18, 2009 - 10:13 PM
tonytutino
Joined Jun 16, '06
like the wiring harness coming from the car that you splice the cd player's harness into. why did you decide to use fuses? because one of the wires coming from the car is a 12v source that connects to your CD player.
post Feb 18, 2009 - 10:15 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i had the factory amp. i rewired the whole system.
post Feb 18, 2009 - 11:00 PM
gt_driFFter
Joined Nov 29, '04
Were you not aware that you could have just used the output harness of the amp? From what you are describing, your 12 volt constant wire is the problem, it's what retains your settings. If you have chopped up your radio wiring too much, just go to the main ignition harness for 12V constant and Accessory.
Edit:
I just reread your post and you have your wires backwards. Yellow needs a constant power source. Red/Accessory needs a source that gets power when the key is turned to the accessory position. Again, if you have mutilated your OEM radio wiring, go to the main ignition harness.
This post has been edited by gt_driFFter: Feb 18, 2009 - 11:00 PM
post Feb 18, 2009 - 11:05 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
thanks. i'll try it. they aren't chopped up... so i'll see if it works.
post Feb 18, 2009 - 11:08 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
post Feb 19, 2009 - 1:17 AM
gt_driFFter
Joined Nov 29, '04
Lo-Fi Version Time is now: January 10th, 2025 - 9:28 AM
