2 Pages V  < 1 2
> Import performance parts question
post Feb 24, 2009 - 2:47 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE (bdawgbp1 @ Feb 23, 2009 - 11:33 PM) *
QUOTE (presure2 @ Feb 23, 2009 - 6:34 PM) *
QUOTE (bdawgbp1 @ Feb 23, 2009 - 6:24 PM) *
Woah - sounds like I may have gotten myself into more than what I bargained for. So you can't just swap the heads and use the same ECU, sensors, etc. Would a piggyback controller do the job?
no and no.
done right, a 5sgte (5s block, stroked 3s crank rods and pistons) and all the other bits, can be a beast.
takes alot of money, and some know how to get done properly tho.
So can I use the stock 5S crank or should I get a 3S-GTE crank and have it stroked for the 2.2 block? Also what about the distributor, intake manifold, throttle body, and exhaust manifold? Thanks for all your help. smile.gif
I hope you know what you're getting into. I think ice23q, a member here with a 5sgte, has put almost $20,000 into his build. Obviously it can be done cheaper than that, but it's still going to cost at least 4 or 5 grand to get it done right.
if you're seriosu about it, look over at mr2oc.com, they'll likely have a lot more info about it than here.
post Feb 24, 2009 - 2:56 AM
bdawgbp1
Joined Feb 14, '08
From Shelbyville, TN
Yeah - I planned on driving it the way it is right now and slowly buying all the parts as being married with 3 kids doesn't allow for alot of extar money for my "toys". I figure by this time next year I'll have all the parts and ready to tear her apart. I appreciate all the help and info.
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 26th, 2024 - 4:23 PM
