> Updated Manual Transmission Conversion, Checklist
post Oct 29, 2005 - 5:15 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Auto/manual conversion checklist:
Manual tranny
Flywheel and bolts
Clutch kit (and pressure plate bolts)
Driver's side mount for manual
Shifter assembly
Shifter cables
Clutch pedal assembly
Brake pedal (or grind down your stock one)
Clutch master cylinder
Clutch slave cylinder (if not included with tranny)
Clutch lines
Manual ECU or wire in resistor box for the auto ECU
I just wanted to put this down so that I don't have to retype it every time someone asks me how to do it smile.gif
Feel free to add thoughts and comments.
-Doc
This post has been edited by Dr_Tweak: Oct 29, 2005 - 5:16 AM
Click here to see my swaps
drtweak@phoenixtuning.com
post Oct 29, 2005 - 10:41 AM
ILuvMyCelica95
Joined Dec 16, '02
biggrin.gif - just a thought- what about a price range on this as well?- although i assume you can get some parts from a junk yard... hmm
post Oct 29, 2005 - 3:19 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
my clutch pedal assembly, brake pedal and assembly, shifter, and clutch lines were 140$ from the local junkyard
post Oct 29, 2005 - 10:47 PM
Dr_Tweak
Joined Mar 31, '04
I can usually get everything in that whole list for about $700.
-Doc
post Oct 30, 2005 - 8:31 AM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
sticky this!
post Oct 30, 2005 - 9:54 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
Clutch return spring. You may need a manual starter relay. I didn't use one, but I can start my car w/o the clutch in, I just leave it out of gear when its off as my safety switch.
As for the ECU, it's not needed at all, your OD light just blinks, yank the bulb.
You need tranny mounts too. Auto and manual ones don't line up.
TRD Quickshifter is shorter than stock throws, and it comes WITH A SHIFT ASSEMBLY. So you can save some bucks here and get a nice QS kit.
There's various clips and pins to hold the shift cables in too. I am so stupid and didn't save my list. It was so comprehensive for a GT.
- Ryan
aim: rkgreen04
post Oct 30, 2005 - 11:36 PM
Dr_Tweak
Joined Mar 31, '04
QUOTE(Akimbo @ Oct 30, 2005 - 2:54 PM)
[right][snapback]350643[/snapback][/right]
You don't need a manual starter relay, you just need to route the wires that used to go to the Neutral Start Switch to the Clutch Start Switch.
Also for OBDII cars ('96 and up) you are going to need the ECU hack or manual ECU.
As far as I know, only the driver's side mount is needed, is this correct or no?
-Doc
post Oct 31, 2005 - 2:14 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
Yep. Only the drivers side mount! I was looking over my parts today and I got a couple mounts i didn't use.
- Ryan
aim: rkgreen04
post Oct 31, 2005 - 12:57 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
So if it cots $700 for the parts. How much for install and labor from a normal shop? And then how about u dr. tweak? How much does phoniex motoring charge for that???
Kawi Love
post Oct 31, 2005 - 1:12 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
You can't make an estimate for a normal shop. Everyone is totally different. And there is no gaurantee about 700 for parts. The main thing is the transmission and flywheel, clutch. the tranny alone is gonna be the big chunk. Mine was 450 and had 10k miles on it.
- Ryan
aim: rkgreen04
post Nov 1, 2005 - 1:01 AM
Dr_Tweak
Joined Mar 31, '04
Normally when I do a conversion to manual, I do it at the same time as an engine swap. When you consider the expense and difficulty of doing JUST an auto/manual conversion, and compare it to doing an engine swap AND auto/manual conversion, it's not worth it to most people to just do the conversion.
I would charge around $300 for labor on just a conversion, so it would be around $1000 total. On the other hand, I charge an additional $150 when doing it at the same time as an engine swap.
Another thing to consider is that when you get and engine set it normally comes with a 5-speed tranny already, you can usually use the clutch that's already installed, you have the mount probably, so it cuts down on what you would have to spend when doing just a conversion.
post Nov 4, 2005 - 12:26 PM
devilsden97
Joined Jun 13, '05
I found a 5-speed transmission with all the parts needed to do the full swap. It is at a local salvage yard. The guy quoted me $700 for all the parts. This inculdes all the stuff listed at the start of this thread. I told him i was doing a swap, and he sounded kinda upset (like it was alot of work for him to take it out of the totaled car) but he said he has everything, its just gonna take some time to get it all out. Also when i said i was doing a swap the guys said, "so your gonna need the cylinder?" (im assuming hes refering to the clutch cylinder) So i figure this guy has some idea what hes talking about. Cuz i totally for got about that part. lol So yeah.
Should i bring him the list on this forum, so he knows exactly what i need? just to make sure i get what i need?
BTW i have a 1995 GT, and im replacing the Auto tranny with a gt 5-speed, so it should be one of the "easier" tranny swaps (not saying any are easy, but just from the fact its the same motor as what it is suppose to be connected to.)
Kawi Love
post Mar 15, 2006 - 1:12 AM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
QUOTE(Dr_Tweak @ Oct 29, 2005 - 5:15 AM) [snapback]350305[/snapback]
Manual tranny
Flywheel and bolts
Shifter assembly
Shifter cables
Clutch lines
-Doc
i found this on another celica website rite here
Parts List
With part number when available
Transmission junkyard
Clutch master cylinder 31410-20470
Clutch pedal bracket 55107-20330
Clutch pedal 47101-20430
Clutch cancel switch had on hand
Brake pedal 31301-20380
Pedal pads x2 31321-14020
Clevis pin 90249-08143
Clevis pin bushing 00000-00000
Wave washer 90206-08001
Clip 90468-16142
Bolt clutch pedal hinge 90101-10015
Nut 94110-51000
Bushing pedal x2 90386-13015
Collar shaft 90387-10003
Cushion pedal stop x2 90541-06036
Return spring 90507-14029
Shifter assembly 33530-20550
Shift cable 33821-20682
Range cable 33822-20252
Cable clip x4 90468-14016
Clutch line lower came on trans
Clutch line clip x2 00000-00000
Slave cylinder came on trans
Trans mount 12372-74200
Flywheel junkyard
Flywheel bolts 00000-00000
Clutch pressure plate throw out pick your brand
Pressure plate bolts x6 don’t have # on hand
Trans bell housing bolts x3 grab ‘em at the yard
Starter relay junkyard
Clutch start switch 00000-00000
but i think its just for a 5 gc
what do u guys think?
would it be the same on a 6gc?
This post has been edited by XS4lv1Truch0x: Mar 15, 2006 - 1:13 AM
Is this good enuff 4 ya? :D
post Mar 20, 2006 - 10:21 PM
Dr_Tweak
Joined Mar 31, '04
No, but it's still a good reference.
-Doc
post Mar 31, 2006 - 11:56 AM
Cavanagh
Joined Mar 21, '06
From Springfield, IL
What all those numbers mean after the PArt?
post Mar 31, 2006 - 1:02 PM
Chanh55
Joined Jun 29, '03
QUOTE(Cavanagh @ Mar 31, 2006 - 8:56 AM) [snapback]416081[/snapback]
Those are Toyota Part Numbers.
post Jun 8, 2006 - 4:58 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
other than the 6g gt tranny is any other tranny going to work???..
post Jun 8, 2006 - 6:19 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i think the same trannys that will work with the 3sgte/3sge but youd need a hybrid clutch kit for them.. someone correct me if im wrong though, its just a theory
post Aug 3, 2006 - 12:30 AM
QUOTE(Dr_Tweak @ Oct 31, 2005 - 12:36 AM) [snapback]350887[/snapback]
-Doc
2 questions...
1 - where are the wires for and/or where is the Neutral Start Switch ? and you would just route them to the clutch start switch (on the pedal) correct ? (or leave cut and don't start the car in gear)
2 - and as for a 96+ conversion...if you just swap from a 1997 A/T ECU to a 1996 M/T ECU (both 7A) will that be fine ? are the pinouts on both ECUs the same (same locations) ? I know there would be some extra wires not being used (for the auto tranny) but are we talking just plug and play here ?
thanks
This post has been edited by Batman722: Aug 3, 2006 - 12:47 AM
post Aug 3, 2006 - 9:12 AM
Dr_Tweak
Joined Mar 31, '04
QUOTE(Batman722 @ Aug 3, 2006 - 5:30 AM) [snapback]464838[/snapback]
2 questions...
thanks
Hey, I got your PM.
1. They are located on the large plug on the tranny, usually they are black and black/white. You can either route them to the clutch start switch, or connect them and don't start the car in gear. The easiest way to route them to the pedal is to connect them together at the tranny plug side, and then on the interior find the wire (with a multimeter or check the diagrams) and then cut and splice two wires in there. That saves you from having to run wires through the firewall.
2. If you swap ECUs, on the '96, I can't recall at the moment but on the manual ECU the third plug is a 12-pin instead of a 22-pin, I'm pretty sure. It's easier to just connect three resistors in place of the shift solinoids, I even have the resistors that you would need in stock here if you want them. They're like $25 shipped. Otherwise, check on that plug size on the ecu and then we'll go from there.
Also I think the rear mount bracket is different, make sure that you have the one for the manual tranny.
-Doc
Lo-Fi Version Time is now: November 23rd, 2024 - 2:33 PM
