FS: Brake System upgrade, 2pot ssIII Caliper, Altezza Caliper with 300mm Brembo |
Feb 20, 2009 - 9:41 PM |
Enthusiast Joined May 25, '06 From Hong Kong Currently Offline Reputation: 256 (100%) |
There are 3 sets of Brake kit for sale:
(A) Front 2 Pot/Piston Caliper with Stocked 275mm Disc + Brand New Aftermarket Brake Pad (This kit was on a JDM ST202 with Super Strunt Suspension) 2 Possible Modification - Use your existing Disc and Caliper Bracket, just Bolt on the 2 Pot Caliper - Trim down the Disc and use back your existing Caliper Bracket, just Bolt on the 2 Pot Caliper Just Caliper(With or without Bracket) + Brand New Pad = USD$130 Everything= USD$180 (B) Previous Pics, exactly how it look A rough idea to show u how big is the brake kit, my previous 17" rims x 7J offset35 Caliper and Adapter (Another set from friends here in Hong Kong, used to be on a ZZT231) Front 2 Big Pot/Piston Caliper with Brembo 300mm Disc + Adapter + Used Brake Pad The Calipers were on a JDM Altezza RS200, same spec as Lexus IS200/IS300 and had been modified with straight bolt on with a adapter The disc is used but have some wear, 300mm slotted rotor, Brembo Simply Bolt on, but since the Disc Size is 300mm, not sure 16" or smaller Rims could fit in or not, 17" and up could fit in well USD$310 Would Post more pics for each item later on, could ask for more spec upon request Since I would ship those kit out from Hong Kong. The Shipping for above items must kill, I will ship by Hong Kong Post, can choose from via Surface, Air or EMS. The following link could give u a rough idea on the shipping cost http://app1.hongkongpost.com/calc/eng/overseas/step1.php This post has been edited by vincent_doggy: Mar 18, 2009 - 8:00 PM -------------------- |
Feb 21, 2009 - 12:52 AM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
On option B there, just curious, but how many bolts secure that adapter bracket for the caliper??? I only see a hole for a single bolt to hold the adapter bracket, and if that's the case, call me crazy but I think that's extremely dangerous. Can you get some pictures of Option B as mounted on a Celica without the wheel in the way, preferably from the backside?
Feb 21, 2009 - 10:39 AM |
On option B there, just curious, but how many bolts secure that adapter bracket for the caliper??? I only see a hole for a single bolt to hold the adapter bracket, and if that's the case, call me crazy but I think that's extremely dangerous. Can you get some pictures of Option B as mounted on a Celica without the wheel in the way, preferably from the backside? lol, I am not as crazy as u think, there are 2 bolts, 1 on each side. Try to take another pics for ya if have chance Btw, Option B just sold locally!! -------------------- |
Mar 5, 2009 - 6:21 PM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
what is that 2pot/piston caliper from? and is a) a set? like 2? or is it just 1 side?
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Mar 5, 2009 - 8:20 PM |
what is that 2pot/piston caliper from? and is a) a set? like 2? or is it just 1 side? From a JDM ST202, its a Super Strunt Suspension, not sure its a ssII or ssIII Gonna be left and right, I can sell just the front pair of caliper or caliper with rotor But since this pair is for S.S. Suspension and the rotor/disc is larger, say 275mm, you need to trim it down like 9mm or 10mm. if not just replace the caliper with this. Hope this can help. might take some pics and post later -------------------- |
Mar 18, 2009 - 8:01 PM |
Pics Update!!
Lo-Fi Version | Time is now: November 30th, 2024 - 12:41 AM |
