My 5S-FTE build thread, my turn |
Apr 23, 2009 - 12:11 AM |
well the car is running but all the stock stuff is back on. i couldnt get the AEM FIC to work. the engine ran but it was stumbling bad. so im trouble shooting the FIC in NA mode. once its all working, then ill put the turbo stuff back on.
Apr 26, 2009 - 11:38 AM |
Its alive and running. FIC is working! it was a wiring problem. now i just have to put turbo stuff back on and start tuning.
Apr 28, 2009 - 8:56 AM |
i installed the 460 injectors yesterday. i used the simple build base MAP function in the FIC. the software asks for stock injector size and new injector size. it then calculated a base MAP. engine ran a tad rich so i pulled some fuel. no problems running perfect, but i have a fuel leak around injector 1 so i have to check that out.
Apr 28, 2009 - 8:59 AM |
i installed the 460 injectors yesterday. i used the simple build base MAP function in the FIC. the software asks for stock injector size and new injector size. it then calculated a base MAP. engine ran a tad rich so i pulled some fuel. no problems running perfect, but i have a fuel leak around injector 1 so i have to check that out. good to hear man! get that leak fixed up, fire would suck. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 28, 2009 - 9:01 AM |
Thanks, oh i figured out why my valve train sounds like a diesel engine too. all my intake valves are .006 loose. i dont understand how that happened. exhaust valves are perfect...im going to build a tool so i dont have to pull the cam.
Apr 28, 2009 - 9:25 AM |
some info on the FIC
well, how its hooked up is by intercepting the crank + signal. the FIC has an input and output, so its inbetween the crank signal and the ECU. the injector signals flow the other way out if the ECU into the FIC box then to the injectors. the software is very user friendly. right click the fuel MAP and select build base MAP. input new injector size and stock injector size. it automatically fills the cells with settings. i couldnt get a straight answer on stock injector (210-220) so i used 215 and im using RX7 460 injectors. so for anything below boost levels has a value of -53. as boost increases it is adding fuel. Timing works the same way, you can pick -1 degree for every pound of boost, or -2 degrees for evey psi. and so on. The FIC can only retard timing, it cant add. so far im really pleased with it. ill put the turbo system back on soon. i have a small fuel leak at #1 injector so i have to check that out. -------------------- 2001 Celica GT-S Turbo
Jul 6, 2009 - 10:07 AM |
just a small update. im still running in N/A mode. still have the 460 injectors in and running the FIC. i havent had a single lick of problems and im getting about 28 MPG in town. i have done NO tuning to the FIC. im running on the base calibration maps that the software generated +1 for the FIC. i really need to get an RC bumper so if anyone has one or knows of one for sale, let me know!
Apr 7, 2010 - 8:58 AM |
Update....Well i hate to say it but im not a big fan of the FIC anymore. again it could all be because im lacking some tuning. I think all my problems will be solved if i get the 3S-GTE MAP sensor. right now im clamping the stock MAP sensor and i think its just messing with everything. no matter how much fuel i dump into the fuel MAP the stock ECU is overriding it. the FIC and stock ECU are fighting waaay too much. plus im also suffering from the "dirty" toyota sensors issue. apparently toyota signals are very dirty and the the FIC has a hard time with that.
well to make a short story long... i got the plugs and pins to make my own jumper harness so i can use my AEM EMS for my All-Trac on the 5S-FE. having a full standalone will make it soooo much easier to tune. -------------------- 2001 Celica GT-S Turbo
Apr 7, 2010 - 8:18 PM |
Update....Well i hate to say it but im not a big fan of the FIC anymore. again it could all be because im lacking some tuning. I think all my problems will be solved if i get the 3S-GTE MAP sensor. right now im clamping the stock MAP sensor and i think its just messing with everything. no matter how much fuel i dump into the fuel MAP the stock ECU is overriding it. the FIC and stock ECU are fighting waaay too much. plus im also suffering from the "dirty" toyota sensors issue. apparently toyota signals are very dirty and the the FIC has a hard time with that. well to make a short story long... i got the plugs and pins to make my own jumper harness so i can use my AEM EMS for my All-Trac on the 5S-FE. having a full standalone will make it soooo much easier to tune. THAT is where it is at. once you get that hooked up and running right, i smell great things for team 5sfte! interested in a set of cams for that beast? +30whp on the top end... -------------------- Former Team 5SFTE pro member ;)
Apr 8, 2010 - 5:19 PM |
I just talked to Aaron at ATS Racing mentioning the EMS idea and he had never done that setup before. He did say that he doesnt see any reason why it wouldnt work. i have the wiring diagrams for both the 5S and 3S here so i guess all i have to do is figure out the pin changes.
He also mentioned that he has a few Gen 2 MAP sensors for a good price if anyone is looking for them. -------------------- 2001 Celica GT-S Turbo
Apr 8, 2010 - 6:03 PM |
I just talked to Aaron at ATS Racing mentioning the EMS idea and he had never done that setup before. He did say that he doesnt see any reason why it wouldnt work. i have the wiring diagrams for both the 5S and 3S here so i guess all i have to do is figure out the pin changes. He also mentioned that he has a few Gen 2 MAP sensors for a good price if anyone is looking for them. yea, i cant see why it wouldnt work, you should be just fine. i cant wait to see some screenshots of that. when you slapping on a real turbo and going for broke???? good luck man, looking forward to your results. -------------------- Former Team 5SFTE pro member ;)
Apr 10, 2010 - 8:31 PM |
well i have most of the pinouts figured out. most of them are the same. but there are a few small differences. Manny, Dt Tweak, Jim, perhaps you can help with this.
the 5S Distributor has a G+ signal which i believe is the cam position, that relates to the G1 on the 3S. the 5S also has a crank position sensor that labeled NE, there is also an NE on the 3S. are they the same? the 3S-GTE ECU also has a G2 and G- for the distributor. what are they? Another difference is that the 5S has a radiator input? its pin C15 lables CF, there is no 3S equivalent? -------------------- 2001 Celica GT-S Turbo
Apr 10, 2010 - 11:26 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
well i have most of the pinouts figured out. most of them are the same. but there are a few small differences. Manny, Dt Tweak, Jim, perhaps you can help with this. the 5S Distributor has a G+ signal which i believe is the cam position, that relates to the G1 on the 3S. the 5S also has a crank position sensor that labeled NE, there is also an NE on the 3S. are they the same? the 3S-GTE ECU also has a G2 and G- for the distributor. what are they? Another difference is that the 5S has a radiator input? its pin C15 lables CF, there is no 3S equivalent? G1 sends crankshaft angle to the ecu G2 is the same as G1, but is 180* out from G1 G- Ground fro G1,G2 and NE Look inside the 5s dizzy to see if there is a 24 tooth trigger wheel. Because the 3s has one. NE is the positive signal for the 24 tooth wheel. It sends the engine speed and crankshaft angle to the ecu. Sorry got off topic, the whole 24 tooth wheel made me think of the honda dizzy haha I am working on the Honda ecu to work with the 5sgte right now, but having issues, maybe could be a bad burn or messed up jumper wiring. I doubt its the wiring since I went through it over and over again. This post has been edited by bccentaur3: Apr 10, 2010 - 11:27 PM -------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Apr 11, 2010 - 12:26 AM |
thanks for the info
so is the 3S dizzy a Hall style and the 5S i know is a mag style. im not sure how many teeth are on the 5S Dissy but there are definatly teeth and a flat side for a mag style, just like the crank pos sensor -------------------- 2001 Celica GT-S Turbo
Apr 11, 2010 - 12:36 AM |
What do you mean by Hall style?
Apr 11, 2010 - 1:07 AM |
there are 2 types of cam position sensors, mag and hall style
are NE and G1 the same? -------------------- 2001 Celica GT-S Turbo
Apr 12, 2010 - 3:24 PM |
ok i have all the answers i need i think. i have labeled all the wires and started sodering. its not going to be pretty. this is very fustrating. i have just about reached the point where im going to buy a premade harness like the one i wired in my FIC and just cut and paste the correct pinout. ill will post the schematic when im done and everything is working. it will be nice having a stand alone for the 5S-FTE, too bad its so $$$$
May 27, 2010 - 9:18 PM |
i built my patch harness. the AEM EMS is installed and working (somewhat) the car wont start. i cant figure out why. gotta check some grounds.
Jan 11, 2011 - 6:15 PM |
Enthusiast Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
Whats the results so far Smaay?? |
Jan 12, 2011 - 12:43 AM |
i havent had time to finish this project. but as soon as i finish these turbo kits ill get back to it. i do want to finish this project because it would be nice to have a full standalone
Lo-Fi Version | Time is now: November 24th, 2024 - 5:34 PM |
