> Rear suspension problems
post Feb 24, 2009 - 1:44 AM
JonMarkos
Joined Jun 13, '06
From Omaha, Nebraska
Hey guys, looking for some input from those with more knowledge than me. My right rear wheel clunks when I drive. It sounds almost exactly like it would if you have ever driven off from somewhere without tightening your lug nuts all the way (my lug nuts are tightened all the way). I also have on new tires so that is not the problem. Is there a bearing in there that will go out causing this to happen? I noticed that the clunking goes away when I am going around corners which I attribute to the wheel being pushed up against whatever is loose (if that makes sense). Any help is greatly appreciated, thank you.
We shall show mercy, but we shall not ask for it.
post Feb 24, 2009 - 5:15 AM
Salica
Joined Dec 28, '08
From long beach, CA
not sure but look at struts(shocks) , strut mounts, that your spring are sitting correctly. check the e brake assembly someone had some noise coming from there a while back. other than that make sure everything is tighten and look for abnormalities.
-good luck
post Feb 24, 2009 - 6:24 AM
trdproven
Joined Aug 2, '05
From Guam
make sure your strut nut is tight
endlinks are not gone
sway bar bushings are not gone
not confident that it is strut mounts or shocks since it is the rear since the rears have lots of travel room. Plus your car is not low. if it were shocks, it would be rattling, couldn't be a strut mount because they just sit there in the rear unlike the fronts that turn. Cannot be springs not seated right because they create popping clunks, like you can really tell the springs cause it.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 24, 2009 - 9:11 AM
jimmykay
Joined Jul 14, '08
From St. Louis
Is the sound constant? or is it just once in a while, like going over bumps?
'99 Celica GT - Sold
'11 Mazdaspeed3
post Feb 24, 2009 - 11:21 AM
JonMarkos
Joined Jun 13, '06
Salica, I'm pretty sure it is not my struts or springs.
TRD I'll double check my endlinks and sway bar bushing although I don't see how those would cause this noise.
Jimmy, the sound is constant when driving straight.
post Feb 24, 2009 - 12:57 PM
jimmykay
Joined Jul 14, '08
From St. Louis
Griffgirl had a post not too long ago that sounds like it might be similar to what you've got going on.
http://www.6gc.net/forums/index.php?showtopic=65030
check that out and see.
'11 Mazdaspeed3
post Feb 24, 2009 - 1:04 PM
JonMarkos
Joined Jun 13, '06
Griffgirl describes a grinding noise. My vehicle makes a thumping noise, almost exactly like what lil joe mentioned when he posted in that thread. It is related to the wheel because the noise speeds up or decreases along with how fast I am driving.
post Feb 24, 2009 - 5:31 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (JonMarkos @ Feb 25, 2009 - 2:21 AM) *
if no sway bar bushings the bar will move around and clank around the bracket. If the endlinks are bad, they will move around like a broken joint. I've done suspension many times and have changed these parts out for many cars.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 24, 2009 - 5:40 PM
trdproven
Joined Aug 2, '05
From Guam
lift up your car wiggle your wheel from top and bottom and left to right. if its loose theres your problem. This will also prevent alignment.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 24, 2009 - 10:53 PM
JonMarkos
Joined Jun 13, '06
TRD you are the man. Although I was wrong on the side. It is my driver's side rear wheel, and it appears that it is a bushing that has gone out allowing the wheel to wiggle while driving. Here is a picture
The writing I did is tiny but the bushing on the left is bad.
In this picture it is the rod closest that has the bad bushing on the end. Does anyone know if it is possible to remove that bolt and just replace the bushing inside of there or do I need to buy a new rod? Also, what is the real name of that rod so I can look it up? Thanks for the help so far.
post Feb 24, 2009 - 11:09 PM
JonMarkos
Joined Jun 13, '06
After looking at the rear schematics closely I believe it is going to be number 5 in this diagram that I need
I may even end up needing number 2 since the wobbling of number 5 may have loosened up number 2 as well. It is listed at 1sttoyotaparts.com as the rear arm. 1sttoyotaparts has it listed separately for years 95-99 and for convertible, or coupe w/ or w/o sport package. Is there actually a difference?
post Feb 25, 2009 - 5:32 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Figured that'd be the cause -- those are the suspension arms, and they are infamous for the mysterious clunk when driving over less than perfectly flat roads.
Unfortunately, it's not a bushing. The ends of those arms use spherical bearings, which while theoretically replaceable would cost about as much or more to get the bearings, plus the cost of removal and replacement.
The rearmost of the pair is the No. 2 suspension arm (the front is the No. 1 suspension arm, further differentiated by L -- driver's side -- and R). You're pretty much stuck replacing the entire arm, which runs about US$90 from 1sttoyotaparts.com (it's identified there as a lateral arm under the rear suspension section).
The long bolt running through the axle carrier is likely seized and will be extremely difficult to remove -- albeit not impossible. If you can get the nut off it, replacing the No. 2 arm is actually quite easy. The No. 1 arm is much more involved.
Actually, I had to replace both my No. 2 arms on my 1990 GT, and decided to use the sixth-gen suspension arms because the toe adjuster is threaded rather than the easily misaligned eccentric cam used on fifth-gens. Here's a link to a guide I wrote for Celicatech: http://www.celicatech.com/forums/showthread.php?t=34935
post Feb 25, 2009 - 3:42 PM
the1
Joined Feb 25, '09
From Austria
You can also bushes of Super Pro take.
Super Pro
OEM bushes boring the easiest way around to pierce the rubber, metal sleeve out and the remaining rubber spring almost out of myself.
ST205 and ST185
Toyota Streben Nr. 48780A -> SuperPro SPF0823K
Toyota Streben Nr. 48710A + 48720A -> SuperPro SPF2264K
post Feb 28, 2009 - 12:12 AM
trdproven
Joined Aug 2, '05
From Guam
yea tie rods are also infamous for breaking. ^ those look real good, are they really made for st202 and st204?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 28, 2009 - 12:10 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Given the equipment pictured is for the ST205, I'd be really surprised. Moreover, the ST205 originally used rubber bushings, versus the ST204 using spherical bearings -- the rear wheels being drive wheels for the GT4.
Lo-Fi Version Time is now: November 27th, 2024 - 4:42 AM
