> Smoke and Burning?, Ive search but i need more help
post Feb 24, 2009 - 5:47 PM
sapperk
Joined Mar 9, '03
From Orting, WA
Once the car gets to operating temp, a strong burning smell is comming from engine. Light black smoke is comming from muffler and lots of white burning smoke is comming from engine. It sort of is comming from behind the alternator down below. Can not track it completely. Any ideas?
post Feb 24, 2009 - 5:55 PM
sounds like your waterpump is going bad.
post Feb 24, 2009 - 8:09 PM
sapperk
Joined Mar 9, '03
From Orting, WA
The water pump and timming belt was changed out about 2 years ago, and the car hasnt really been driven for about 8 months?
post Feb 24, 2009 - 8:59 PM
Remy
Joined Jan 25, '06
From MN
Are you losing coolant or oil at all ?? How many miles on the motor ?? What brand water pump was used ?? And if your cars been setting for 8 months with no gas stabilizer you probably have bad fuel too.
This post has been edited by Remy: Feb 24, 2009 - 9:00 PM
"To Protect And To Serve The Wealthy" -POLICE
post Feb 24, 2009 - 9:13 PM
sapperk
Joined Mar 9, '03
From Orting, WA
Not loosing coolant or oil, dont know what water pump was used. Factory OEM im sure. About 120K miles. Maybe bad fuel? But must be something else...
What about gaskets? What about exaust gaskets? Can they be an issue? Where the manifold connects to the exaust pipes underneath the engine?
Oh by the way if it matters, its a 5SFE, 1996 Celica GT.
post Feb 24, 2009 - 11:20 PM
sapperk
Joined Mar 9, '03
From Orting, WA
So im thinking bad fuel now, with the black smoke comming from muffler. If it is bad fuel, if i just add some more good gas and maybe an additive ya think that might do it?
post Feb 25, 2009 - 10:37 AM
Remy
Joined Jan 25, '06
From MN
I would drain it out or syphon it out lol and if you could see smoke coming from below the alt and your guessing its from one of your exhaust piping it could be a bad gasket or you could have a crack somewhere.
post Feb 25, 2009 - 10:40 AM
sapperk
Joined Mar 9, '03
From Orting, WA
You 6Gc guys are the best, im gonna try to work the gas thing later today and see whats up. If that doesnt fix it i guess ill go and strip some things apart and try to trace the issue a litttle better. Hopefully some fresh gas and a little octane booster will do the job. Maybe clean my injectors also. Thanks guys for the advice and input...
post Feb 27, 2009 - 12:16 PM
sapperk
Joined Mar 9, '03
From Orting, WA
Well i changed the gas, the problem actually looks a little better, but it is still happening. I wanna change the gaskets in my exaust but i cant get THE FREAKING BOLTS out. Im sure they havent been out ever and the car is a 1996. WTF i feel like such a newb, i just dont wanna run into any more problems by screwing it up, or snapping bolts or something.
post Feb 27, 2009 - 1:23 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
cant help you with your problem... but i am wondering how you made/got that tube around your intake??
post Feb 27, 2009 - 1:30 PM
JustinCapps
Joined Jan 17, '09
From Hilo Hawaii
post Feb 27, 2009 - 1:58 PM
sapperk
Joined Mar 9, '03
From Orting, WA
The heat shield? It came with it, Injen
post Feb 27, 2009 - 2:26 PM
6G96GT
Joined Jan 20, '08
From East Coast
Black smoke is fuel...running rich? White smoke is coolant...gotta leak...does it smell sweet in the engine bay or even a bit fishy? You can always get a pressure test on the cooling system to see if you have a leak somewhere. I think it runs $30-$50
This post has been edited by 6G96GT: Feb 27, 2009 - 2:27 PM
Lo-Fi Version Time is now: November 26th, 2024 - 6:35 PM
