> projectors, they are not RHD!
post Feb 25, 2009 - 3:54 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
ok so i just got my projectors in and i took them apart... the right hand projector has the cutout just like the left hand does... they are not Right hand drive or left hand drive... also look at the pic in the how-to for LHD use... the lens is a convex lens... which means the image would be rotated 190*... the "cutoff" portion is actually towards the center of the car and is found on both sides... just a little info i thought i might add... so US guys.. no reason to break open your projectors unless you want to paint them like me.... smile.gif smile.gif
Breaking Axles...
post Feb 25, 2009 - 4:38 PM
manphibian
Joined Oct 13, '06
From UK
They are for right hand drive.
the beam flicks up on the left hand side for people who drive on the left.
post Feb 25, 2009 - 6:03 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
would you read what i just said... it does not flick up on the left hand side... the housing for the left and right hand sides are identical...
Breaking Axles...
post Feb 25, 2009 - 6:14 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
pics asap!
post Feb 25, 2009 - 6:21 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
heres the best i can do without taking my projectors back apart... i will also get some pictures of the light output against a wall without modifying the projectors...
this is of the driver side (US) from the how-to.... this is looking at the projector from the front.... the image (light) will get flipped 180* once it passes through the convex lens following this cutoff... therefore this is used to limit the vertical distance from the ground that is projected... giving you the line... once its rotated... the "cutoff" portion will be toward the center of the car... not on the outside like other people seem to think...
Breaking Axles...
post Feb 25, 2009 - 10:01 PM
trdproven
Joined Aug 2, '05
From Guam
i totally understand what you mean but like luke they do light up higher in the beam on the road towards the left side. My us cars light up more on the right hand side. Not sure why its like that but I have no intention of modifying mine - keeping it as is.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 25, 2009 - 11:48 PM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE (pittfirefighter @ Feb 25, 2009 - 6:21 PM) *
Have you actually been in a car with unmodified projectors?? Let me tell you from experience, they are for right hand drive. The projector lens works just like your eyeball, whatever goes through gets inverted. So with the pic above, the low point would be bottom right, making the high point of the light top left when flipped as it goes through the lens. So the cutoff that was added at the bottom right actually cuts the light output on the top left down to a flat line with the rest of the cutoff.
I have the remnants of my projector sitting here from my accident and just looked through the lens to verify even. They are NOT LHD, they are NOT center justified. They are RHD, nuff said.
This post has been edited by Fastbird: Feb 25, 2009 - 11:49 PM
post Feb 26, 2009 - 5:47 AM
QUOTE (Fastbird @ Feb 25, 2009 - 11:48 PM) *
X2.
----\____ that is the beam pattern.
it is made that way for LHD.
not that it matters. ive had mine in for YEARS with no issues at all.
post Feb 26, 2009 - 7:24 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
There are no OEM LHD projectors... if... just if... you really have LHD ones someone already converted them.
note: I had the same feeling when I saw them inside... but do tot forget lens of projector converting it... so beam is mirrored.
post Feb 26, 2009 - 7:25 AM
manphibian
Joined Oct 13, '06
From UK
QUOTE (presure2 @ Feb 26, 2009 - 10:47 AM) *
post Feb 26, 2009 - 11:18 AM
Fastbird
Joined Jun 25, '05
From Fort Wayne, IN
QUOTE (presure2 @ Feb 26, 2009 - 6:47 AM) *
X2.
I had mine unmodified since we put them in and never received a flash from oncoming traffic. The ONLY reason why I'm modifying them at this point is because I'm putting an HID kit in the car and would rather not take any chances with screwing with oncoming traffic.
This post has been edited by Fastbird: Feb 26, 2009 - 11:18 AM
post Feb 26, 2009 - 12:14 PM
geetje
Joined Sep 23, '07
From Netherlands
I got projectors and I too had to modify them.
I've never seen projectors for LHD.
This post has been edited by geetje: Feb 26, 2009 - 12:15 PM
post Feb 26, 2009 - 1:12 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
QUOTE (Fastbird @ Feb 26, 2009 - 5:18 PM) *
X2.
With normal bulbs - you may be able to get away with it, but with HID - its dangerous when blinding on coming traffic. X2 - needs to be modified to be safe.
post Feb 26, 2009 - 4:13 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
what you said proves my point... this is the FRONT of the projector... THINK ABOUT IT.... i wish i had a pic right now but the RIGHT HAND projector has the exact same cutoff...
This post has been edited by pittfirefighter: Feb 26, 2009 - 4:14 PM
Breaking Axles...
post Feb 26, 2009 - 4:15 PM
manphibian
Joined Oct 13, '06
From UK
You're wrong. get over it
Of course both lights have the same pattern. They BOTH flick up on the left rolleyes.gif
post Feb 26, 2009 - 4:17 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE (manphibian @ Feb 26, 2009 - 4:15 PM) *
they both have a dip to the outside... if you don't understand physics please don't argue with me
Breaking Axles...
post Feb 26, 2009 - 4:19 PM
manphibian
Joined Oct 13, '06
From UK
Whatever.
They are for RHD cars, whatever you say.
How is this not RHD?
I wouldn't want that in my face if i was driving on the right!
post Feb 26, 2009 - 4:26 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
ok thank you.. .but i just want to know the physics behind it... thats all... it shouldn't be like that in theory
Breaking Axles...
post Feb 26, 2009 - 4:37 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
if somebody has a moment... while my projector is getting replaced... UPS broke the tabs off... could i see the light output of the left hand light ALONE unmodified... thanks!
Breaking Axles...
post Feb 26, 2009 - 5:55 PM
sorry, i meant right hand...gimme a break, it was 5:45am after being up with my daughter....lol
but yea, hid's or not, i dont have any problem with them, i've been flashed MAYBE 3 or 4 times in the years ive had them.
Lo-Fi Version Time is now: November 25th, 2024 - 4:24 PM
