6 Pages V  « < 3 4 5 6 >
> im bored heres a few teaser pics ;), *update* now with dyno chart!
post Jul 28, 2011 - 8:59 PM
iburnslabs
Joined Sep 22, '02
From colorado
one more teaser before we fire her tomorrow! finally , so excited to drive this thing again!
94 Supra~12.10 @ 114 mph 1.74 60' @ 5800 elevation STOCK FUEL! (SOLD)
94 ST205 (converted) 13.1 @ 101.68 mph 1.71 60' @ 5800 elevation (SOLD)
95 ST205........ 495 AWHP under the knife for a better engine build then for sale....... 600 awhp here i come!
post Jul 28, 2011 - 10:13 PM
Still expecting 495 WHP?
post Jul 28, 2011 - 10:28 PM
iburnslabs
Joined Sep 22, '02
From colorado
lol no we made that last time smile.gif going for 600-650 this time if everything holds together ha
post Jul 29, 2011 - 11:08 PM
iburnslabs
Joined Sep 22, '02
From colorado
well she started up, but shes NOT happy lol. not sure what went wrong but im literally spitting raw fuel out the exhaust??? i changed to ID2000 injectors, FPR is reading correctly, went all the way to 0.01 on fuel on the AEM but still spitting gas out the exhaust! litterally putting your hand behind the tail pipe will wet your hand completely in 1 second lol. wont stay running without opening the throttle obviously due to too much fuel. we did delete the injector box double checked everything... WTF!!! any ideas anyone???
post Jul 30, 2011 - 1:48 PM
iburnslabs
Joined Sep 22, '02
From colorado
Fixed ! Stupid 3.5 bar map sensor was bad its alive!
post Jul 30, 2011 - 3:52 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
vids you lucky man you!!!!
post Jul 30, 2011 - 7:56 PM
chacha
Joined Dec 29, '05
From So-Cal
i want one of your cars
post Jul 31, 2011 - 12:23 AM
iburnslabs
Joined Sep 22, '02
From colorado
and a bad wheel bearing..................... NOOOOOOOOOOOOOO!!!!!!!!!!! lol anyone got one off a clip for sale??????? front left. could use a hub/knuckle lol
post Aug 8, 2011 - 12:04 AM
iburnslabs
Joined Sep 22, '02
From colorado
i did get this fixed, she is back on the road thanks to fensport for super fast shipping. but man super expensive haha. ill get some updates when we tune it. but she is on the road and running smooth of the road tune for break in smile.gif
post Nov 24, 2011 - 10:20 PM
iburnslabs
Joined Sep 22, '02
From colorado
i know its been a while, but i finally got to the dyno, about 450awhp on 17 actual psi (not gauge pressure due to altitude), had some ignition breakup issues so had to stop tuning, got it fixed will be back at the dyno on wednesday with some huge numbers hopefully! the goal is 35 psi well see if the stock ignition holds up! will update with a dyno chart on wednesday
post Nov 29, 2011 - 9:04 AM
Sunny
Joined Nov 15, '10
From Austria
Hi,
do you or your programmer doesn't fear knocking with the 9:1CR at sucha high boost?
was there any problems by welding the AN fittings to theval vecover, or do i have to know anything?
greetz
This post has been edited by Sunny: Nov 29, 2011 - 9:05 AM
KEEP COOL UNDER PRESSURE
post Nov 29, 2011 - 11:05 AM
iburnslabs
Joined Sep 22, '02
From colorado
no fear in knocking at all, i have seen some 3sgte's get pushed way harder then i am about to push this one with no issues. i trust my engine builder and my tuner so i think all will be well. no problems with welding AN fittings to the cover as i had my long time friend and very skilled welder do that for me and powder coat it red.
post Nov 29, 2011 - 2:16 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
that are good news
such a big turbo, does i ask you when the turbo spools and what cams you are using?
greetz
post Nov 29, 2011 - 4:32 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
did you go with GSC cams? i dint know they made them for the 3S-GTE. I just bought the stage 2 cams for my Supra. as soon as i get moved into my new house ill be rebuilding the mighty 2JZ-GTE. Also why such big injectors, are you planning on running E85? And why didnt you clock the turbo down, with all your custom work being done, it would be so much cleaner clocking the turbo down.
This post has been edited by Smaay: Nov 29, 2011 - 4:48 PM
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Nov 29, 2011 - 7:12 PM
iburnslabs
Joined Sep 22, '02
From colorado
clocking it down would hit stuff..... its pretty tight down there... yes gsc cams, 274 duration 10mm lift. turbo spools full boost around 5000 which is pretty quick considering at 6000 feet elevation or so we lose a couple hundred rpms of spool, ill have a dyno chart tomorrow to post after i tune on high boost.
post Nov 29, 2011 - 7:39 PM
iburnslabs
Joined Sep 22, '02
From colorado
O and it is currently on E85, thats why the large injectors, the 1200cc injectors were at 70 percent duty at 20 psi on the old gt35r
post Nov 30, 2011 - 1:42 PM
iburnslabs
Joined Sep 22, '02
From colorado
off to the dyno for tuning.... back in a few hours with either really good news or terrible news haha. stay tuned....... (no pun intended)
post Nov 30, 2011 - 10:28 PM
iburnslabs
Joined Sep 22, '02
From colorado
just an update, first of all i made a typo earlier, we made 350 whp on 17 psi on boost on the last dyno session, today we made 498 @ 24 psi of boost, which its funny it made 525 @ 25 psi of boost (the turbo just got into efficiency lol) but then we had iginition breakup, the stock ignition cant handle 25 psi.... time to upgrade and go back to hit 650++ lol but it runs amazing is is pretty quick. i am going to do a coil on plug setup and go back for more power ASAP! , runs super smooth to 9000 rpms tho on 24 psi i am getting a taste of what is to come after adding some spark. i will upload a dyno sheet tomorrow.
post Dec 1, 2011 - 4:11 AM
chacha
Joined Dec 29, '05
From So-Cal
Damn...you're a crazy man with lots of money. can i work for you so you can build me one?
post Dec 1, 2011 - 4:19 PM
iburnslabs
Joined Sep 22, '02
From colorado
im a one man show, dont need any employees hehe. im going to do the coil on plug conversion with an AEM cdi (already bought them waiting to get them and install) so i can turn her up to about 35 psi. as for building another one..... no no no no no lol ive got 40k into this dam thing including the car, she is for sale if you are interested in buying it ?? smile.gif
45 User(s) are reading this topic (45 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 13th, 2025 - 9:28 AM
