Enthusiast ![]() ![]() ![]() Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) ![]() |
So I asked my mech to install an oil press. gauge and he did. I noticed it was tapped into the block and I asked him about the debris from the drilling if it would cause any scoring or anything. He said they grease the drill bit so the debris sticks to it or something and they use a magnet too. It sounds weird to me, is this accurate????
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) ![]() |
I've heard of people drilling and taping the oil pan for a turbo set-up using that method, but not into the block.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) ![]() |
I agree with centaur, i thought they always did it into the oil pan not the block.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) ![]() |
ive heared of people doing it with intercooler piping etc.
being a fitter and machinist by trade im not a fan of it, sure you can grease the tap and the drill bit, but is it worth risking ruining your engine??? i think not. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
So I asked my mech to install an oil press. gauge and he did. I noticed it was tapped into the block and I asked him about the debris from the drilling if it would cause any scoring or anything. He said they grease the drill bit so the debris sticks to it or something and they use a magnet too. It sounds weird to me, is this accurate???? he tapped into the block? or head? like 'pilot said, sure, it may work, but why would you wanna risk it IMO. if he did drill and tap the block, get some pics, i would love to see where he did so. -------------------- Former Team 5SFTE pro member ;)
He said block, I haven't seen the car yet since it went it the shop early last week. I should be getting it back Monday. I will post up later monday evening. Thanks guys but now I am a little worried about it.
wtf? just get a T fitting and T off of where the stock pressure sender threads into. or use an oil filter sandwich plate to get pressure reading.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
wtf? just get a T fitting and T off of where the stock pressure sender threads into. or use an oil filter sandwich plate to get pressure reading. +1 for filter sandwich, I've got one sitting here with my gauge waiting to go on when I change my oil lol -------------------- 1999 Celica GT
So I asked my mech to install an oil press. gauge and he did. I noticed it was tapped into the block and I asked him about the debris from the drilling if it would cause any scoring or anything. He said they grease the drill bit so the debris sticks to it or something and they use a magnet too. It sounds weird to me, is this accurate???? Alright guys, so my mechanic put the oil pressure gauge into the head. Here's another question though, after I installed the header, hi flow cat, removed the small cat at the original exhaust mani, and with the SRI and Exhaust Muffler I have now, should I tune the car?? What'll happen if I don't? |
nothing will happen if you dont.
you could benifit a little from tuning out some of the fuel curve with somthing like an SAFC, but its not somthing you HAVE to have right now. -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
it can be done in the block, i have personally done this. yes you can use grease and a magnet to prevent shavings from getting the system but i dont recommend it. i did it because i had to do it that way.
you cant do oil pressure at the pan, there is no pressure in the pan. its all after the oil pump. the best place to do it is like hoe the FTE guys get oil for the turbo. get a bypass fitting for the head where the factory pressure switch is. -------------------- 2001 Celica GT-S Turbo
Good to know about the tuning issue, I've already spent my max $ limit anyway. My mechanic said my car was a real pain in the a$$ to work on too. He said it took him like 2 hours to get the timing correctly set up. I still don't have it back yet but he said monday so I'll let y'all know how it runs.
Good to know about the tuning issue, I've already spent my max $ limit anyway. My mechanic said my car was a real pain in the a$$ to work on too. He said it took him like 2 hours to get the timing correctly set up. I still don't have it back yet but he said monday so I'll let y'all know how it runs. wow. if your mechanic takes 2 hrs to set mechanical timing on a 5sfe, its time to start looking for a new mechanic. -------------------- Former Team 5SFTE pro member ;)
no kidding, that takes 20min tops...including warming the engine to operating temp.
Alright, I got the car back today. Just drove it home 20 miles. My mechanic had to put a new flex pipe on with some new bigger piping as well. I had the Hi Flow cat installed at the same time with the header which is wrapped. It sounds good but not like I suspected.
Will it get louder and throatier eventually??? Also, what is the correct PSI at normal operating temp (at idle) for the oil pressure??? Mine is run from the head. It reads 10 PSI at idle and at 65MPH it reads 55 PSI steadily. It kinda seems low to me but I don't know. I checked the oil and it's at the right level and nice and clean. No leaks under the cars except for some brake fluid but that's an old issue. |
Alright, I got the car back today. Just drove it home 20 miles. My mechanic had to put a new flex pipe on with some new bigger piping as well. I had the Hi Flow cat installed at the same time with the header which is wrapped. It sounds good but not like I suspected. Will it get louder and throatier eventually??? Also, what is the correct PSI at normal operating temp (at idle) for the oil pressure??? Mine is run from the head. It reads 10 PSI at idle and at 65MPH it reads 55 PSI steadily. It kinda seems low to me but I don't know. I checked the oil and it's at the right level and nice and clean. No leaks under the cars except for some brake fluid but that's an old issue. it may get a tiny bit louder, but not much at all. oil pressure sounds about right..i get ~ 12.5 at idle. -------------------- Former Team 5SFTE pro member ;)
Cool, good to know about the oil pressure.
I thought the header with an opened exhaust and hi flow cat would sound kinda on the mean side, but it actually sounds like there's no header at all. It will get louder over the next couple hundred miles right? By the way, how do I post pics? |
Cool, good to know about the oil pressure. I thought the header with an opened exhaust and hi flow cat would sound kinda on the mean side, but it actually sounds like there's no header at all. It will get louder over the next couple hundred miles right? By the way, how do I post pics? i cant really say if it will get louder. upload your pics to a hosting place like photobucket.com then copy the [img] tags to your post. -------------------- Former Team 5SFTE pro member ;)
Alright, thanks
Another quick question...I asked about Oil Pressure. Mine reads 10 PSI (into the head) at idle under normal operating temp. Presure2 mentioned his was 12.5. I've noted that my Oil Press reads 35 PSI at 2K rpm and 49 PSI at 3K rpm. Does this sound accurate?
Lo-Fi Version | Time is now: February 20th, 2025 - 2:50 PM |
