> ST215 Engine Swap, Harder than from an ST205
post Oct 11, 2003 - 9:27 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Would swaping in a ST215 3SGTE be any harder than Swapping in one from an ST205? If so do both engines have the same potential. I'd like to be making 300 to 400HP from it after all is said and done.
post Oct 11, 2003 - 9:32 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
price per HP you would be better off doing a 185 swap - more parts for it and you can order parts from local toyota dealer
post Oct 11, 2003 - 9:38 PM
ST185 is the easiest swap - and when i say easy, I mean not really that easy. ST205 swap is difficult for the experienced, I dont even kno if ne body has done the 4th Gen 3SGTE swap simply because the motor is not all the old so its really expensive, and the wiring is 100x harder because cars get more electronic and more computerized every year.
post Oct 11, 2003 - 9:44 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Will the ST185 3SGTE be able to handle 300 to 400HP. I figured since the ones from the ST205 and ST215 had higher HP ratings that they'd be able to handle more. Maybe I'm a little confused but wouldn't it be easier to put one from the ST205 or ST215 into an ST202 since they are of the same years. Wasn't the ST185 the 5th Gen Celica All-Trac?
post Oct 11, 2003 - 9:49 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
The blocks are basically identical.. the top ends are where the differences are between the engine gens.
The 215 as far as I know has different motor mounts but is still a "s" series engine so maybe it would work - havent really looked into it.
The 185 is the best option unless you have alot of cash to modify the 205. The 185 stock internals will hold around 400hp no prob, any higher though and you will have to bump up the internals.
as for the same years... it really doesnt make that much difference - if it's JDM you will still have to lengthen the harness 185 or 205. the mounts are pretty much all the same between 165,185,205
yes - and MR2 Turbo
This post has been edited by NEVERSTOP: Oct 11, 2003 - 9:50 PM
post Oct 11, 2003 - 9:59 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Thanks for the help NEVERSTOP sounds like the 185 is the way to go. What kind of internals should I go with. Would the APEXi 2.2l Stroker kit and Metal head gasket be a good start or should I start somewhere else. Would the Stroker kit make that big of a difference or should I even bother. Also what's the highest HP output from a 3SGTE you've heard of?
post Oct 11, 2003 - 10:19 PM
QUOTE (WannabeGT4 @ Oct 11, 2003 - 6:59 PM)
If you're going to get the stroker kit, the best time to put it in is while the engine is out of the car before your swap. Keep in mind that it's going to cost you a lot of money and it's not necessary to achieve 400 horsepower. As for power gains, I'm sure you'd gain a pretty good amount of power from the increased displacement and reduced rotating weight, and the components replaced would be much stronger.
Oh yeah, I've seen a 3S-GTE in a JZA80 Supra producing over 800 horsepower. smile.gif
post Oct 11, 2003 - 10:20 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
The HKS one would probably be one of the highest.. but not sure what it was off hand just know it was a BIG number... expecally from a 4 cylinder.
I wouldnt bother with a stroker kit or anything until you wanna go above 400 but you could do it if you want.
post Oct 11, 2003 - 10:34 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Thanks guys. Sounds like you know what you're talkin bout. I would definately put the stroker kit in while it was out rather than pulling the engine to do it later. What I'm really looking for is potential in the engine so that I can run it at 400 and be able to add on later or crank up the boost. Now that you mention it I remember seeing the HKS one and yeah it was pretty powerful but I heard a rumor that it was actually a modified 5s block. Have you heard anything like that?
post Oct 11, 2003 - 10:36 PM
The mechanical part of swapping is easy, its the electrical part which is th emost difficult.
post Oct 11, 2003 - 10:49 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (Supersprynt @ Oct 11, 2003 - 9:36 PM)
Sounds good I shouldn't have a problem with it then as long as I can find some schematics.
post Oct 12, 2003 - 6:58 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
well when you find some schematics be sure to post a link
post Oct 12, 2003 - 7:13 PM
edo17982
Joined Dec 21, '02
From Italy
Here is the pic of 720HP 3SGTE. Here are specs:
3SGTE 4 Cylinder 720HP @ 1.8 Bar and 8500 rpm's
2.2 Liter Garage Fukui SPL
GReddy T88 34D Turbine
Top Secret Dry Sump Oil System
Race Head with HKS Metal Head Gasket
100mm Veilside Throttle Body
4 - 540cc Injectors in Main Rail
4 - 550cc Additional Injectors
HKS F-CON V Pro ECU
OS Giken Triple Plate Clutch
Getrag 6 Speed
TRD Rear End
post Oct 15, 2003 - 4:26 PM
Rivo
Joined Apr 28, '03
QUOTE (Coomer @ Oct 11, 2003 - 8:19 PM)
Pike's Peak MR2 with the 3sgte had 900 some odd HP, insane.
post Oct 15, 2003 - 4:58 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
QUOTE (edo17982 @ Oct 12, 2003 - 5:13 PM)
HKS F-CON V Pro ECU
Getrag 6 Speed
TRD Rear End
edo, that motor was created by suprastore.com
here is the link, they are selling it for like $23,500
SupraStore.com
post Oct 15, 2003 - 6:49 PM
Inferno
Joined Jan 30, '03
From Virginia
When I get my car and do the swap, I was thinking about the JUN Stroker Kit. I've heard some good things about JUN and not really anything bad, so, they seem good.
From what I understand, the Stroker Kit allows you to turn up the boost TONS because of the extra displacement and strength of the components.
HKS did a car that runs 9's, and that is equipped with a 3S-GTE. The power possibilities of this monster is unreal.
post Oct 15, 2003 - 7:02 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
QUOTE (sphinx_race911 @ Oct 15, 2003 - 2:58 PM)
HKS F-CON V Pro ECU
Getrag 6 Speed
TRD Rear End
SupraStore.com
no suprastore did not make that, top secret did, and they had it in there supra but since that didnt sell they are just selling the engine. the day suprastore builds a 3sgte like that is the day me **** turns purple and tastes liek rainbow sherbert
Lo-Fi Version Time is now: December 1st, 2024 - 7:30 AM
