> can anyone tell me where to find step by step instructions for changin, can't afford to have a garage do it so im going to try it myself&#
post Mar 13, 2009 - 8:14 PM
mahem109
Joined May 11, '08
From culpeper, VA
I have a haynes manual but it is sketchy on just how to change the clutch in my 95 gt. If there is somewhere i can go to get detailed instructions from start to finish on how to change this i would be thankful. I have done many repairs myself over the years and any heads up i can get would be great!!!
This post has been edited by mahem109: Mar 13, 2009 - 8:47 PM
post Mar 13, 2009 - 8:25 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Changin what?
post Mar 13, 2009 - 8:42 PM
mahem109
Joined May 11, '08
From culpeper, VA
QUOTE (Spider77 @ Mar 13, 2009 - 8:25 PM) *
Changin what?
the clutch in my 95 celica gt.
post Mar 13, 2009 - 9:14 PM
ZGear
Joined Feb 16, '07
From BP, MN
http://www.autozone.com/shopping/repairGui...900c152800750f7
Will give you the general idea.
post Mar 13, 2009 - 9:30 PM
mahem109
Joined May 11, '08
From culpeper, VA
QUOTE (ZGear @ Mar 13, 2009 - 9:14 PM) *
again, that is really sketchy, doesn't really cover all that is needed to do to remove the trany. How do you remove your axles? etc. I am looking for a little more in depth than a remove everything out of the way and unbolt the transmission. what am i going to run into along the way? What are the hard parts like seperating the trans from the block, does this just fall off the block or am i going to have to pry it apart, if so what is the best area to pry from. I am looking for the tricks of the trade. Im sure there are some tricks that i am not seeing or hearing about.
post Mar 13, 2009 - 10:15 PM
ZGear
Joined Feb 16, '07
From BP, MN
Haven't done one, but it's held on by bolts and it will drop making a hole to china. You're gonna need a good lift to hold and lower the transmission down.
This post has been edited by ZGear: Mar 13, 2009 - 10:16 PM
Lo-Fi Version Time is now: November 27th, 2024 - 11:44 AM
