> Nasty clunks and bumps, clunks when i barely go over anything
post Mar 14, 2009 - 3:58 PM
gomezjose26
Joined Feb 11, '09
From houston
i just bought my celi and have had it for a month now and for some reason the car makes the clunk sounds when i steer the car go go over anything. also when i go over a small bump the a rattleling noise comming from the front frown.gif
post Mar 15, 2009 - 11:59 PM
relyks95gt
Joined Sep 29, '08
From miami
new struts, there gone
-RELYKS
post Mar 16, 2009 - 10:01 PM
WORK4POOP
Joined Jan 31, '03
From SoCal
before you go buying all new parts...check the lower ball joint. Sometimes rocks get stuck between the lower arm and the joint. Just lift the car up and poke around with a flat head screwdriver.
post Mar 17, 2009 - 12:57 PM
jcbass7
Joined Apr 20, '06
From Florida
a lot of clunks in the rear are worn out sway bar bushings, cheap fix but that may not be your problem/entire problem
post Mar 18, 2009 - 10:50 AM
gomezjose26
Joined Feb 11, '09
From houston
its all in the front. i got my megan racing coilover damper kit and im just waiting for my new breaks. thanks guys. ohh and there was no rocks lol thanks
post Mar 18, 2009 - 1:46 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
check your control arm in the ffront it might be old and needs replacement. worn out bushing and stuff can cause your car to clunk and stuff while shifting..or riding over bumps..
Lo-Fi Version Time is now: December 1st, 2024 - 1:50 AM
