> Cooling System flush, how to refill PROPERLY after a flush
post Mar 14, 2009 - 6:53 PM
ksporry
Joined Mar 14, '09
From Portishead
Guys,
Am brand new here. Today I flushed the cooling system of my Celica GT. I was not aware of any drain plugs on the engine block, so I'm not sure if I flushed it correctly.
Basically what I did, was I set the heater to full on, hoping this would flush the cabin heating system as well. Then I disconnected the two main hoses between the engine and the radiator. With the radiator empty, I reconnected the bottom hose, and ran the engine until it started pumping water out of the upper main hose. After that, I filled it up with water (about 2.5-3 liters each time) and let the engine cycle this out again. I did this about 10 times until I saw clear water come out. Then I filled up the radiator with half the previous amount (so about 1.5 liters) and added one of those cleaner chemicals (as per instructions on the cleaner). I followed the instructions which said I had to either drive it 30 miles or run it high idle for about 10-15 minutes. I ran it about 20 minutes. Again I detached the top hose and let the engine spit out the stuff.
Filled up the radiator again full (still only about 2,5-3 liters, which seems very little to me), and let the engine spit out all the crap. Followed up with two more cycles like that, until the water was clean again.
Since tonight I read about drain plugs for cooling system, which I did not use, I wonder if my method was adequate.
Also, I wonder what the best next step is. I find it hard to believe that the system only takes about 3 liters of coolant. To me that sounds like the radiator taking 3 liters which is much more plausible. I now want to fill it up with coolant. Assuming that indeed the 3 liters fill up the radiator only, I am wondering if I should poor in the coolant up to filling the radiator and then leave it at that (unthinned coolant fluid. I'm considering that there may be another 2 or 3 liters of water in the system).
I also wonder what i should do to fill it up properly. Should I fill it up and then run the engine hot without the cap on the radiator? Should I wait and see if the level in the radiator drops, and then top it up again? If anyone could give me some instructions (before I blow my engine...), that would be great!
Also, what type of coolant should I use? I know of 2 types: cheap blue all purpose coolant fluid, and red coolant fluid (which I also know as VolksWagen coolant fluid). A friend of mine said his dad used the red stuff before in a classic car with a steel engine block and found it rusted the engine block from inside. He thinks my engine block may also be steel and therefore corrode if I use the red stuff. Any advice on that?
post Mar 14, 2009 - 7:22 PM
petna
Joined Mar 2, '08
From Manchester - UK
should take over 5 litres iirc. Here in the UK we use the Red Toyota 4Life coolant
www.celica-club.co.uk
My Garage
post Mar 14, 2009 - 7:27 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
I believe theres a drain plug on the back of the 5sfe. There should be a little run off "ramp" type of deal to guide the coolant out.
When i did a flush and fill on my car i drained everything then i had a funnel attached to the radiator. I filled up the radiator then ran the engine till the thermostat opened up and filled up the radiator again and let the engine cycle a few times to make sure i had enough coolant. I turned off the engine and put the rest of the coolant into the over flow tank.
Since your doing this it wouldn't be a bad idea to flush your heater core either.
2nd Gen 3s-gte.... It lives!
97celiman
post Mar 15, 2009 - 4:44 AM
ksporry
Joined Mar 14, '09
From Portishead
Do you recon the red halfords coolant is compatible with the toyota 4 life coolant?
Also, since I didn't manage to find any drain plugs so far (have to admit, I don't have a service manual of any kind so I'm doing all this a bit on rational thinking, and the tips of a friend who's a damn good mechanic...)
post Mar 15, 2009 - 2:26 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
hnm ya i should have drained the system until the engine came out with clean water. i only flushed it twice. oh well i'll learn when i do it again in 10,000 miles from now. Same here i only unpluged radiator hose that attached to the bottom of the radiato and the drainplug. couldn't find the plug that connects to the engine. i also have the chilton celica repair manual which shows where both plugs are at for the gt and st celi.
This post has been edited by BonzaiCelica: Mar 15, 2009 - 2:27 PM
post Mar 21, 2009 - 2:22 PM
ksporry
Joined Mar 14, '09
From Portishead
the one on the bottom is the hose that goes from the radiator to the engine. There should be a big hose on the top as well (on the right hand side, close to the overflow tank)
Lo-Fi Version Time is now: February 17th, 2025 - 5:05 AM
