![]() Enthusiast ![]() Joined Feb 23, '09 From Kahaluu, Hawaii Currently Offline Reputation: 0 (0%) ![]() |
it could also be the half moon on the valve cover gasket, did you seal it? Half moon is where? I'm still learning a lot. thnx i can come by and take a look also if your still having issues next weekend. Thanks. I'm so surprised I have so many people helping. I'll let you know. Where do you live? what about getting a dye additive kit for engineoil @ napa,autozone,or going to a shop & ask the what it would cost to add the dye & check it in a day or so? friend of mine doesnt charge for doing it. the dye can be seen with utraviolet light or special glasses. he uses it to look for leaks in hard-to-see areas. Haven't try that yet. I'll keep that in mind though. Thanx. cam shaft seal or oil pump seal will leak when engine is running. It sounds like the oil pump seal, but i'm not for sure yet. cam shaft seal or oil pump seal will leak when engine is running. It sounds like the oil pump seal, but i'm not for sure yet. -------------------- ------------------------------------------------
808CELICA2DAMAX "May the Boost be with you..." [76 Celica GT LB /85 Celica GTS LB/94 Celica GT LB/87 Celica ST Cpe] 82 Datsun 280ZX / 82 Starlet / 78 Cressida / 03 Tacoma Pre-runner ------------------------------------------------ ![]() |
Lo-Fi Version | Time is now: February 23rd, 2025 - 5:01 AM |
