![]() Enthusiast ![]() ![]() Joined Jun 10, '08 From Virginia beach Currently Offline Reputation: 8 (100%) ![]() |
hey there everyone.
ok, so i got up this morning. got ready for work... went out and got in my car. ![]() feedback??? thanks everyone -------------------- |
Enthusiast ![]() ![]() ![]() Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) ![]() |
Might sound obvious, but is the safc(assuming that's what your using) turning on when you put the key in? There was an issue where it wasn't communicating with my ecu one time, therefore not sending the correct amount of fuel...made my car run like **** for about 20 seconds before it died. Took a little while for me to realize it wasn't getting power and was making my car run as if it was completely un tuned.
Might sound obvious, but is the safc(assuming that's what your using) turning on when you put the key in? There was an issue where it wasn't communicating with my ecu one time, therefore not sending the correct amount of fuel...made my car run like **** for about 20 seconds before it died. Took a little while for me to realize it wasn't getting power and was making my car run as if it was completely un tuned. yeah.. that Neo DOES cut on. i usually let that turn on before i cut my car on. and still nothing :-\ -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
check that your getting spark.
if so, then bridge FP && B+ in your diag box. then try it. if not leave the key "on" and listen, if your Fuel Pump works you'll hear the fuel return sending back all the fuel in the engine bay, and the whine inside the car -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
found the problem
![]() ![]() ![]() ![]() ![]() ![]() the fuel pump fell INTO the gas tank and the hose was disconnected!!! -------------------- |
Enthusiast ![]() Joined Sep 16, '08 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
Lol, good thing you found it!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) ![]() |
I was just about to tell you there are a lot of things to check. Since you found the problem already, how did that happen?
im guessing i just didnt have the hose clamps tightened down enough :-\ so i def made it tight as hell now. just very scared to hit bumps in the road now
Lo-Fi Version | Time is now: February 24th, 2025 - 2:14 AM |
