Right side CV axle, CV axle help |
Mar 19, 2009 - 8:09 AM |
Enthusiast Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) |
how do I remove the mount from the old right side CV axle? The braket is mounted on the ball bearings of the right CV axle and wiggles just a bit but wont come off.
Mar 19, 2009 - 8:38 AM |
You're going to have to press it off - you might have to bring it to a shop.
But why do you want to remove it? -------------------- |
Mar 19, 2009 - 8:52 AM |
you could hammer it off but it's going to be very difficult and possibly damage the bearings.. it would be much easier and safer to use a hydraulic press to push it off.
Mar 19, 2009 - 10:05 AM |
yea, hammering it will just ruin the bearing.
you need to press it off. any local shop should be able to do it for a minimal fee if you cant do it yourself. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Mar 19, 2009 - 1:51 PM |
The RH axle is broken so I replaced it but the bearings on the new axle are showing and that mount on the broken axle looks like it protected the bearings from being messed up. Thanks for your help guys I'm gonna take it in to press
Lo-Fi Version | Time is now: November 27th, 2024 - 6:53 AM |
