107 Pages V  « < 88 89 90 91 92 > »
> Tigawoods' 1995 Celica, Racing n Stuff
post Jul 17, 2016 - 1:17 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I guess its a little harder to paint fiberglass/carbon hoods than I thought
This post has been edited by Tigawoods: Jul 18, 2016 - 7:31 AM
エキサイティングカーレーシングチーム!
post Jul 17, 2016 - 3:53 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Wow real awesome. Cool points be going through the roof. But a sunroof, hmm. 32 lbs of savings, 33 without headliner
This post has been edited by BonzaiCelica: Jul 17, 2016 - 3:57 PM
post Jul 17, 2016 - 4:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
Looks great, hopefully it accomplishes what you're wanting.
2001 Miata LS 5-speed
post Jul 18, 2016 - 7:37 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (BonzaiCelica @ Jul 17, 2016 - 4:53 PM) *
yeaup. one day. Ill cut out a panel from a non sun room and make a removable panel or something
QUOTE (Box @ Jul 17, 2016 - 5:04 PM) *
once ducted it should.
Id like to see if its working now without the ducting but: cant get the temp sensors on the Racepak to read properly and I need some yarn and a gopro to see how the airflow is coming out and hopefully not in. In the case that its going in, a gurney flap will have to be put in front of the vent
エキサイティングカーレーシングチーム!
post Jul 18, 2016 - 8:29 AM
cheela
Joined Feb 2, '07
From Berlin, WI
looks great. interested to see the airflow as well.
but *gasp* no washer nozzles!? what will u do when a fly hits your windshield while you're racing?!
post Jul 18, 2016 - 8:47 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
QUOTE (cheela @ Jul 18, 2016 - 8:29 AM) *
Yolo
-Alex {](O_o)[}
post Jul 18, 2016 - 12:36 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (cheela @ Jul 18, 2016 - 9:29 AM) *
it will be obliterated into dust due to the rocket like speed my car will be going
エキサイティングカーレーシングチーム!
post Jul 18, 2016 - 4:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
It might be worth doing a Gurney flap anyway, look forward to seeing the results.
post Jul 19, 2016 - 7:30 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
non hood related update.
went yesterday to get the hubs installed only to find out I made another oversight.
The camry hubs I have use a different size bearing from the celica.
SO.
In my sheer frustration and anger from this whole hubs situation I just ordered new RAV4 hubs from the dealer with overnight shipping so that I can get them here, put the new studs in, install the hubs, align the car, and have the car ready for the trek up to CSP
If these hubs have the same small stud hole issue as all these damn reman'd hubs, Im done with this whole extended stud thing for a while. If a lug backs out it backs out....thats why we have 5 lugs right? backup
エキサイティングカーレーシングチーム!
post Jul 19, 2016 - 11:01 AM
I tought i told you the bearings were different. I tried before with one
post Jul 19, 2016 - 3:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (njccmd2002 @ Jul 19, 2016 - 11:01 AM) *
Hmmm...
QUOTE (Tigawoods @ May 22, 2016 - 9:11 PM) *
QUOTE (njccmd2002 @ May 22, 2016 - 9:35 PM) *
i picked up one from a camry, and the bearing was different.
The bearing I could see being different but was the actual hub different?
Took out one of the studs from the Solara hub and its knurl measured .557". The IS300 ARP studs I have are .558"
Also came across a hub manufacturer in PA.
SKF. They have listed on their site a hub that fits a 94-03 V6 Camry and 99-06 V6 Solara. I just saw it as good info that he hub will fit but I will also call to see if they also do the weird stud bore.
post Jul 20, 2016 - 6:12 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
I was thinking it was the OD that was different and not the ID as well.
Sadly I was in the middle of the stud bore frenzy...I was blind to everything haha
エキサイティングカーレーシングチーム!
post Jul 20, 2016 - 5:23 PM
Lol. It happens. Just when you think everything is going right, it crumbles
post Jul 20, 2016 - 5:49 PM
I happen to have a camry front hub. The idea was the same. But i wanted to replace the whole front hub for the celica. Mount points are similar. But never measured. Idea was to use this caliper to try gt4 or supra calipers
post Jul 21, 2016 - 11:48 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
the mount points look VERY similar but like most of these things I bet there is a small difference between the two. Worth looking into though
finally.
the hubs to rule them all!
worth the trouble in the end. They look alot better than the junkyard hubs I had. Probably better to go this way than re-drill some Dorman hubs, I would be too frightened of any imbalance caused from not perfectly aligned drilling
If all goes well, Ill be putting everything back on this evening and aligning the car tomorrow morning
エキサイティングカーレーシングチーム!
post Jul 21, 2016 - 11:55 AM
Box
Joined Feb 23, '12
From Warrior, AL
Moral of the story, just buy the expensive OEM parts to begin with. tongue.gif
post Jul 27, 2016 - 9:14 AM
looking good dude!
if you're still in the NoVa area let me know and we should hit up cars and coffee
post Jul 27, 2016 - 1:25 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Box @ Jul 21, 2016 - 12:55 PM) *
that truly is the moral of the story
QUOTE (playr158 @ Jul 27, 2016 - 10:14 AM) *
looking good dude!
I will probably get down there in the Fall sometime. Once this heatwave is over
エキサイティングカーレーシングチーム!
post Aug 1, 2016 - 11:28 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
few pics from the past couple weeks of travels. I still need to upload the couple pics I took at Tuner Evo
When installing the knuckles, I took a look at the calipers and saw that this little patch had the powder coat removed, which makes me think that using a thinner rotor might be a good idea. The 30mm's may be a BIT too thick.
Unexpectedly ran into Jeff on the way up to CSP!
makeshift vent cover for a flash storm that came through
got in the 10mm spacers and put them on yesterday.
I am not sure if they rub yet but itll be close! Fitment is now completely to my liking now
This post has been edited by Tigawoods: Aug 1, 2016 - 11:30 AM
エキサイティングカーレーシングチーム!
post Aug 1, 2016 - 12:07 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
is it really that loud that you require ear plugs to drive the car?
-Alex {](O_o)[}
Lo-Fi Version Time is now: January 10th, 2025 - 8:51 AM
