107 Pages V  « < 93 94 95 96 97 > »
> Tigawoods' 1995 Celica, Racing n Stuff
post Apr 3, 2017 - 1:31 PM
cheela
Joined Feb 2, '07
From Berlin, WI
the lip flares out at the side which is kinda mimicked by the side skirts as well so it could work.
As for mounting, the lip can be held on by double-sided tape where it touches the bumper on the sides and in the middle grill area. That's how i did my TOMs lip. Not sure how the bottom of that lip is as it's fiberglass rep but the TOMs lip has mounting points that line up with where the underplastics attach to the bumper so maybe you could make something simliar to mount it. My lip is definitely not permanent as I used to take it off when I drove it in the winter and it took all of 5 minutes to mount/unmount.
This post has been edited by cheela: Apr 3, 2017 - 1:31 PM
post Apr 5, 2017 - 11:10 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
You are right they do kind of match in that sense.
I'm sure the OE or TRD skirts would match better.
Maybe I am underestimating the hold of tape? I have some but was really hoping for a more solid mount. Something that would prevent a tearoff from a bit o downforce
This post has been edited by Tigawoods: Apr 18, 2017 - 8:05 AM
エキサイティングカーレーシングチーム!
post May 2, 2017 - 8:41 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
tackling a few tasks concurrently
lip and skirts still are at paint
instead of building a new smaller diffuser or re-doing the one I already made I saved the money I would have used on that, sold the CUSCO underbrace and grabbed
I had been eying these for the past 2 years and had been frequently checking in to see if I could get them anodized a different color. no go
so I got them powder coated
picked up some RPF1's for cheap. the fronts are going to be tricky to fit so I am not sure if I will keep them or not
and the lucky 96 camry that was kind enough to donate its hubs to me.
had to push out the pos next to get some space to access the camry
エキサイティングカーレーシングチーム!
post May 3, 2017 - 3:49 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
Looking good! keep it up!
post May 3, 2017 - 8:43 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (Tigawoods @ May 2, 2017 - 8:41 PM) *
Just one lip hey? wink.gif Did you end up deciding to not keeping the Aeromagic front?
Are those the rear trailing arms? How will those compare in ride to having a Heim joint rather than rubber bushings?
My Celica!
post May 3, 2017 - 11:43 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
Really curious to hear how those T3 rear arms affect ride quality. Racecars gotta drive on roads too sometimes.
June '12 COTM
'95 AT200
post May 3, 2017 - 2:09 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (easternpiro1 @ May 3, 2017 - 4:49 AM) *
he lives!!!!!
QUOTE (jordisonjr @ May 3, 2017 - 9:43 AM) *
I have the Aeromagic and the Euro sides at paint, I am keeping the front lip but the sides...remains to be seen
yup all the arms in the rear.
It will probably be a bit harsher of a ride in the rear but not really noticeable in my situation
QUOTE (HectortheRican @ May 3, 2017 - 12:43 PM) *
my car is stiff as hell already id be surprised if I notice much of a difference
エキサイティングカーレーシングチーム!
post May 3, 2017 - 3:04 PM
Box
Joined Feb 23, '12
From Warrior, AL
You'll just get more harshness transmitted into the body of the car, shouldn't really make it stiffer per se. When I replace the rear arms on the Firebird I was going to go with Johnny/Roto joints since they offer the articulation benefits of a Heim joint but with reduced harshness, plus they can be rebuilt.
2001 Miata LS 5-speed
post May 3, 2017 - 3:30 PM
cheela
Joined Feb 2, '07
From Berlin, WI
T3 stuff is awesome!
I got a list of about $2000 or $3000 worth of stuff to buy from them for my 1st gen. basically all the suspension parts. lol
post May 3, 2017 - 3:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (cheela @ May 3, 2017 - 3:30 PM) *
Nothing wrong with that, pretty much how it is with me and the bird. Everything I want to do is brakes and suspension. You should see if anyone makes a Watt's link for the first gen Celica, I know it's the first major mod I want to do with the Firebird.
post May 8, 2017 - 12:02 PM
mkernz22
Joined May 10, '10
From MA
someone wanted you to check these out mike
http://www.6gc.net/forums/index.php?showto...p;#entry1090099
post May 9, 2017 - 12:08 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (mkernz22 @ May 8, 2017 - 12:02 PM) *
Ahh, I forgot you can't tag people on this forum.
My Celica!
post May 9, 2017 - 2:04 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Yeah I saw them, Ive thought about doing that type of mod for a while but havent found a way for it to look good and still be functional.
Had a pain with the rear knuckles this past weekend.
Those 12" bolts are no joke. Ended up taking it to a machine shop to sort out.
Hopefully it all works out so that I can install this weekend.
Also still looking for a set of wheels to replace the RPF1's. There is no way the front will fit well methinks
エキサイティングカーレーシングチーム!
post May 13, 2017 - 8:49 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
on the eve of what will hopefully be a successful work day, here is a dump of pics from what I got up to yesterday evening
here are some pics of the machined out knuckle bolts and the pushed out trailing arm knuckle bushing, following that are a few pics of what they looked like after I spent a few minutes hitting them with the glass media blaster
towards the end of the night, i found out that the T3 kit is a bit incomplete. On each heim joint are a couple spacers. They come with 2 sizes, one large one used for the big knuckle and subframe bolts and a smaller sixe that is used for the trailing arm knuckle bolts. I guess for whatever reason T3 has 2 of the control arms using the smaller bolts. Which they dont on our car. So I contacted them to see if they could send me the larger diameter spacers. For the time being I am going to see if I can drill the smaller ones out to the size then need to be
I had enough of the large spacers to bolt everything to the subframe but not enough to bolt them to the knuckle
Energy Suspensions Lubricant is AWESOME, id say it is a must have for anyone doing polyurethane bits. So much better then what came with the front LCA bushing from poland.
the DBA rear STI rotors next to the ST205 rears
how I left it for the night
This post has been edited by Tigawoods: May 13, 2017 - 8:54 AM
エキサイティングカーレーシングチーム!
post May 13, 2017 - 4:33 PM
Box
Joined Feb 23, '12
From Warrior, AL
Will be interesting to see how it performs once all back together, shame about them sending the wrong size spacers.
post May 13, 2017 - 7:59 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
isn't this what you made or were looking at making??
http://www.farpost.ru/novosibirsk/auto/gt/...d-42540873.html
post May 15, 2017 - 1:05 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
welp the STI rotors didnt fit...of course. Didnt take very long to figure that out.
They mounted on the hub fine but the issue came when I went to mount the caliper. The disc is 2mm too thick. They are 20mm thick not 18mm as I had read. SO either I may shave them down so its not $$$ down the drain and useless discs OR. Try and redrill the ST205 rotors when after a bit of consideration, looks to be feasible
Also. E-Brake assembly is a pain do. No matter how many times I do it, its always the WORST
QUOTE (Box @ May 13, 2017 - 5:33 PM) *
So far everything has no give haha
QUOTE (BonzaiCelica @ May 13, 2017 - 8:59 PM) *
Yeah, that was before I found other things to do to keep me busy haha
This post has been edited by Tigawoods: May 15, 2017 - 1:05 PM
エキサイティングカーレーシングチーム!
post May 30, 2017 - 10:35 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
got the right spacers in for the arms and re-installed them and re-greased the knuckle bolts to make sure that they never stick again
took time to clean and grease the components in the calipers. took a shot of everything while it is clean
and finally took the time to install the front lip. For a first time putting any sort of exterior mod on the car it went fairly smoothly. The fit inst 100% but It doesnt really bother me.
Next is the skirts, which will be a bit more difficult
also, have to sell the RPF1's since they dont fit. Have my eyes on a set of WEDS that are even lighter.
Found out that Gridlife requires a cage. So I am starting to look into half cages. That means the 3 point rear, harness bar and floor bar may be for sale at somepoint
This post has been edited by Tigawoods: May 30, 2017 - 11:21 AM
エキサイティングカーレーシングチーム!
post May 30, 2017 - 11:27 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Front lip looks great! Looking forward to seeing it all installed.
My Celica!
post May 30, 2017 - 11:33 AM
BonzaiCelica
Joined Apr 24, '08
yea lip looks awesome. I would switch to a pre face bumper along with preface fogs if i had that lip in my garage.
Lo-Fi Version Time is now: February 22nd, 2025 - 11:59 PM
