107 Pages V  « < 104 105 106 107 >
> Tigawoods' 1995 Celica, Racing n Stuff
post Feb 7, 2020 - 8:49 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Looking good Mike!
How did it tow? I'd like to hear your impression of the capability of it.
~bloodMoney
post Feb 7, 2020 - 1:09 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Towed pretty well. It chooses some odd gears at certain points so I think it could benefit from a different selection strategy. MPGs were around 15 so thats not too bad. Acceleration was slightly sluggish but it wasnt anything dangerous. The braking was very good. I dont feel as connected to the brakes and steering as I do in the fit. The brakes I can probably mess with to get where I want, the steering...its a truck so I dont think Im going to match that responsiveness and feel I had in the fit
エキサイティングカーレーシングチーム!
post Mar 22, 2020 - 7:42 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
update:
picked up this crazy cheap red top as a spare backup
good thing I did. I decided i was going to ignore the tapping the motor was currently making as I couldn't figure out the issue and wanted to see if it showed any further issues with a light drive around the block. That lasted all of 10min. An intake valve in Cyl 1 dropped. The pic below is BDC then TDC...valve no move until the piston pushes it up
I was about to just swap the engine over completely but decided to take the head off of the spare motor and maybe rebuild it and put it on.
Currently deciding on how much I want to do to it or just get it cleaned and then put it on.
Compression #s were good on the motor it just needed alot of new seals and pumps and my current one is pretty fresh.
cylinder walls are in ok condition with a bit of wear
oh yah, also got a G4+ Fury because I couldnt wait for them to release the G4X Fury
エキサイティングカーレーシングチーム!
post May 12, 2020 - 9:03 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
head swap and problem found!
as expected Intake Valve 1
took the bucket off to find the keepers kept lol
Under the bucket
damage found...on Cylinder 2&3
Not great but I decided to yolo and bolt it all back up. Everything is running fine but Im starting to collect parts to rebuild the spare block for when this one decided to go
Under the bucket
エキサイティングカーレーシングチーム!
post Jun 15, 2020 - 8:27 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
cars been running okay-ish
It hesitates under load so it dont really get on it. AFR sticks around 14.5 under load and doesnt budge so I am waiting until I get everything squared away with the LINK to hopefully fix this or at the very least help diagnose it better
picked up an accusump from my buddy. Test fitted it, and need to send it out for cleaning.
went to test the basemap and it didnt start. After talking to Mark from Panic made. I thought the LINK was wired for MAF but it is wired for Speed density so it wouldnt start...that and the ECU isnt getting enough voltage during cranking
got a carbon bit. Cant really fit it till the wintertime since the car is outside most of the summer.
cant race or go fast so in the meantime, car meets and pics it is
This post has been edited by Tigawoods: Jun 15, 2020 - 8:28 PM
エキサイティングカーレーシングチーム!
post Jun 15, 2020 - 10:13 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
sunroof delete panel?
-Alex {](O_o)[}
post Jun 17, 2020 - 12:17 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
umm cool micro fiber panel!
dude wtf your car is loud jus saw ig vid
post Jun 17, 2020 - 7:19 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (NgoFcukinWay @ Jun 15, 2020 - 11:13 PM) *
yes and no. I thought I was buying a delete, but it just replaces the glass. But I am going to make it into a delete
QUOTE (BonzaiCelica @ Jun 17, 2020 - 1:17 AM) *
yeah and thats only like 25% throttle lol
エキサイティングカーレーシングチーム!
post Jul 27, 2020 - 6:49 AM
I always wanted to make a CF panel for the sunroof!
Thats awesome dude.
I'm love coming back every few months/years and seeing your work/progress....keep it up buddy!
post Oct 20, 2020 - 8:30 PM
demmahom34
Joined Nov 29, '17
From Columbia, Maryland
Reading this whole thread was a lot but i definitely learned some things and added some things to my spend money list, dont slow down i might catch up
post Nov 25, 2020 - 5:21 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
rolling into the 15th year of ownership I really want to take a big step up and take the car to a new level.
Ive kept mods pretty minimal the past year and a half and focused mostly on things to keep the car running reliably (and also keeping the valves in line which probably also cut down on what I had to focus on)
But slowly this fall I started to form a plan on what I wanted to do. Like most of my endeavors, I'm sure that I am biting off WAY more than I can chew but hoping that by giving myself an early start on planning this fall, that I can get everything together for Spring 2021. This is all new territory for me, lets see how bad I can screw this up biggrin.gif I HAVE NO IDEA WHAT I AM DOING
oh and a nice Lil aux sensor wiring project I did at the beginning of the pandemic
This post has been edited by Tigawoods: Nov 25, 2020 - 5:22 PM
エキサイティングカーレーシングチーム!
post Nov 26, 2020 - 7:46 AM
abflug
Joined Aug 22, '06
From Belgium
QUOTE (Tigawoods @ Nov 25, 2020 - 6:21 PM) *
Nice equipment, which type of camshafts from catcams did you took?
Curious to know if you still have good idling as I'm planning also a set of them.
post Dec 30, 2020 - 6:59 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Late Spring (Hopefully) 2021
エキサイティングカーレーシングチーム!
post Dec 31, 2020 - 7:48 AM
You nuts.
post Dec 31, 2020 - 2:35 PM
BonzaiCelica
Joined Apr 24, '08
errr why you no 3sgte from beginning rolleyes.gif. ummm but honestly people say great flow on vvti heads. how much better is it. 20, 30 hp?? that much more torque as well??
post Jan 6, 2021 - 4:04 PM
cheela
Joined Feb 2, '07
From Berlin, WI
QUOTE (Tigawoods @ Dec 30, 2020 - 5:59 PM) *
BUMP!
Is it done yet?
post Feb 15, 2021 - 5:24 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (abflug @ Nov 26, 2020 - 7:46 AM) *
They are the "Hot Street" 277°/269°'s
they are going to go off to the side for the time being. The billet intake cam "requires" that the buckets be DLC coated to lessen wear. And my spare head needs to be line honed to get rid of the camshaft bearing wear. Im not sure what im going to do about that yet as I could buy 2 Grey Top BEAMS for the price of a line hone for one head lol
QUOTE (BonzaiCelica @ Dec 31, 2020 - 2:35 PM) *
lol, I like to do things the hard way. We will see what it ends up being.
QUOTE (cheela @ Jan 6, 2021 - 4:04 PM) *
BUMP!
Is it done yet?
No. Literally havent even started lol. Like havent seen the car in over a month and its all still together. How hard could this all be? I can do it in a weekend. Maybe 10 weekends.
I am still waiting on pistons. Everything seems to be on backorder. Everything is just hanging out at the machine shop waiting for pistons.
Appointment for manifold fab mid-march so I figure by then things will start moving along.
エキサイティングカーレーシングチーム!
Tigawoods
Joined Dec 22, '06
From Columbia, MD
This post has been edited by Tigawoods: Feb 20, 2021 - 11:50 AM
エキサイティングカーレーシングチーム!
Tigawoods
Joined Dec 22, '06
From Columbia, MD
エキサイティングカーレーシングチーム!
post Jan 28, 2022 - 2:53 AM
BonzaiCelica
Joined Apr 24, '08
pix update??
Lo-Fi Version Time is now: November 25th, 2024 - 1:18 PM
