107 Pages V  « < 105 106 107
> Tigawoods' 1995 Celica, Racing n Stuff
post Feb 15, 2022 - 10:04 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
PIC TIME
engine back from boring and assembly
taped for painting
painted with some eastwood engine paint. this stuff was really great to work with and holds up really well
new block next to the old engine that got pulled out
fun things with assembly, arp main cap studs interfere with the oil pan...found out the hard way but made happy little indents that helped me locate where I needed to make clearances!
Oil pan baffle plate to combat those G's on the track!
mounted the sensor breakout box
Assembled engine
Once in, I tested the fit of the turbo
probably will look alot better with the lip on
removed all the turbo stuff and returned to NA to start the new motor.
once started found a leak that would keep me busy for the next 4 weeks and require me to remove the trans 3 times (i think? maybe 2)
after alot of rear main seal nonsense I think in the end it was this galley plug which the engine builders put in, it was not the exact correct thread spec. I dont remember correctly but the one they put in was like BSPP vs BSPT.
once everything was running I got to use my buddies garage to try and get the turbo fitted before a race (didnt end up getting it in)
took the car out racing to test the motor and everything went well with no hiccups.
got the car a gift, header tank and coolant swirl pot
had a fun time with QC between two different brands of fittings
fitted.
last shoot of the year
no real upcoming plans, just trying to get a house so that the car can finally be in the same state as me during the off season and I can start picking away at getting the turbo fitted and working. There is an annoying squeaking that the engine makes when it gets up to temp that makes it sound like a jetsons ship. That'll get checked out before anything else so I dont get weird looks at stoplights
エキサイティングカーレーシングチーム!
post Feb 17, 2022 - 9:06 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
seems like you got to jump thru 10 hoops for scca rules n reg. i looked that up long ago and thot, wow wtf.
nice paint on the block! but why you still have ps reservoir? why you no move alt to mr2 location?? less heat soakin. maybe you need to cut another hole in hood and put that st205 vent tube apparatus on it if u keeping it in stock location??
post Feb 25, 2022 - 2:17 PM
Ted95
Joined Mar 8, '09
From Westport, MA
Very impressive Mike, I hope to see this car in person again one day
Keep up the progress!
st205 powered ss3 coupe
post Feb 8, 2024 - 11:09 AM
CoolZeen
Joined May 30, '16
From wild 100's, South Chicago
QUOTE (delusionz @ Feb 6, 2010 - 12:45 AM) *
Damn who's interior is that???
mine is almost like that, got the sunshade done to.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: November 22nd, 2024 - 6:36 AM
