> Spark Plug, So I went to autozone..
post Mar 19, 2009 - 11:28 AM
cibrit-
Joined Sep 16, '08
From Michigan
They gave me some BKR63GP Platinum plugs..
Spark Plugs that I have
Would these be fine to put in my car until the next oil change? So approx. 3-4 months
Should I just return them and get the BKR7E plugs?
Thanks,
-Toni
94' Red Celica ST Hatchback: 3S-GTE Swap
Upgrade??: ATS CT27 Kits
-Toni
post Mar 19, 2009 - 11:50 AM
bdawgbp1
Joined Feb 14, '08
From Shelbyville, TN
I'd take them back - someone else step in and correct me if I'm wrong but I believe stock plug on the 1.8 is the NGK BKR5*** plugs. Crucial to install the proper heat range. The BKR6 series is for the 2.2 GT.
post Mar 19, 2009 - 12:35 PM
cibrit-
Joined Sep 16, '08
From Michigan
I probably should have mentioned what engine I've got..
I have 92 3sgte gen2 st185 Turbo mr2 swap.
So will it be different now?
My apologies for not posting my specs..
Thanks,
-Toni
This post has been edited by cibrit-: Mar 19, 2009 - 12:36 PM
-Toni
post Mar 19, 2009 - 5:26 PM
bdawgbp1
Joined Feb 14, '08
OK - sounds more like it. Yeah - those will work just fine - the BKR6 series is the correct plug for the 3S-GTE. biggrin.gif
This post has been edited by bdawgbp1: Mar 19, 2009 - 5:28 PM
post Mar 19, 2009 - 7:12 PM
cibrit-
Joined Sep 16, '08
From Michigan
-Toni
post Mar 20, 2009 - 1:08 PM
95celgt
Joined Oct 5, '03
From South TX.
but its a platinum plug?? from previous research the bkr7es was the best plug for a 3s running over 12 psi...
post Mar 20, 2009 - 10:21 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
as you increase boost you have to go colder so you would want the 7e above 12 lbs... otherwise you risk detonation and knock
Breaking Axles...
post Mar 21, 2009 - 11:08 AM
trdproven
Joined Aug 2, '05
From Guam
pls gap your plugs accordingly.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 23rd, 2024 - 2:33 AM
