Cruise Control Removal |
Mar 20, 2009 - 10:06 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Hey all, need some info on how to properly remove the cruise control cable and module from the engine bay. I have both haynes/chilton manuals plus the toyota service shop manuals all 3 books and it doesn't show or say anything about how to remove the cruise control units so any info would help before I tackle this Thanks.
My cruise control never worked anyway and I don't use it so I could use more space in the engine bay just in case someone asks. -------------------- "To Protect And To Serve The Wealthy" -POLICE
Mar 20, 2009 - 11:30 PM |
1 unplug the acuator, unhook the cable, and unbolt the bracket from the car
2 remove/unhook the cable from the pedal and pull the cable through the firewall (or cut it at the firewall) 3 done 4 if you really want to be cool you can remove the cruise ecu, located to the right of the glove bax under the dash, but no need or just do step 1 and let the cable hang. -------------------- |
Mar 21, 2009 - 12:12 AM |
Enthusiast Joined Sep 13, '06 From St. paul, MN Currently Offline Reputation: 10 (100%) |
Pretty much like Batman said. If you remove the cable it gives you a nice hole in the firewall to run wires for guages, fogs, etc..
If you need an extra hand, gimme a call. -------------------- |
Mar 21, 2009 - 9:01 AM |
Thanks for the info batman sounds simple I'll let you know if I need help muggs.
Lo-Fi Version | Time is now: January 10th, 2025 - 3:03 PM |
