> Braking System
post Mar 22, 2009 - 1:20 PM
twolownissan2002
Joined Mar 22, '06
From Wesley chapel, Florida
Im getting a 97 gt hatchback for parts the car was rolled so there is a few good parts but it does have four wheel brakes. My question is if i was to change out all four wheel is it all going to be a bolt on set up? is there anything that is going to ahve to be modded? Iwill post pics of the set up once i get the car here i just wanted to know before i get in to somthing that i cant do lol
post Mar 23, 2009 - 12:02 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Its as simple as 123 and 456 + 789 and 10, and since the other one is just scrap you can saw off the exhaust pipings to make things easier. I believe for the front brakes, you will need the GT caliper and the GT bracket to make it work with your spindle since the ST has smaller brakes and for the back you need to swap out all the brake stuff since its drums to disc and you need to get underneath the car and swap over the e-brake cables for both sides all the way to you E-brake handle with the GT stuff. Double check the hoses for fitment.
Lo-Fi Version Time is now: February 21st, 2025 - 1:29 PM
